My wife was driving her C4 home from a 100 mile trip and it died about a mile from home (I know...thank goodness) She restarted it and it ran and drove for a few seconds, then died again. It started one more time only for an even shorter period and hasn't started since. I had it towed home thinking I would be able to figure it out. I got a Durametric tool and pulled the codes:
P1130 - Porsche Code 361 O2 sensing adaptation, idle range bank 2
P1128 - Porsche Code 360 O2 sensing adaptation, idle range bank 1
P0455 - Porsche Code 94 - Tank vent system (this is an ongoing issue, replaced cap twice)
P1124 - Porsche Code 167 - Fuel Pump Relay, below limit value
Because the code 167 was fuel related, I thought this was the culprit and replaced the Relay. No love. I still get the code after the replacement. It seems as though I can hear the fuel pump working when I turn the key, could it be that the fuel pump itself is not working like it should? The car turns over fine, but will not fire.
Any help would be appreciated...thanks.
:welcome:
P0455 Fuel Tank Ventilation System (Major Leak) – Below Limit or Signal Implausible
Possible causes:
- Tank cap missing
- Cap seal
- Ventilation lines detached from EVAP canister
- Ventilation line detached from tank
- Ventilation lines detached from operating purge valve
- Ventilation line detached from EVAP canister purge valve
- Break in ventilation lines
- Pressure sensor
P1124 Fuel Pump Relay Output Stage – Below Limit, Above Limit, or Open Circuit
Possible causes:
– Fuel pump relay faulty
– Short to ground, Short to B+, or Break in wiring
– DME control module faulty
P1128 Oxygen Sensing Adaptation, Idle Range, Bank 1 – Above Limit or Below Limit
P1130 Oxygen Sensing Adaptation, Idle Range, Bank 2 – Above Limitor Below Limit
Possible causes:
– Incorrect signal from MAF sensor
– Fuel pressure too high
– Fuel injector leaking
– EVAP canister purge valve open
Based on the codes I see here I would have someone familiar with the fuel lines and the wiring.
I found out how the check the pressure at the access point on the right (passenger) side of the engine under the A/C lines and got 5 lbs pressure when I turned on the fuel pump with the Durametric software. However, I can't seem to find anywhere that tells me what the pressure is supposed to be. 5 lbs. is lower than I expected, but have no clue if it is correct or not. Does anyone know where to find this info?
  • 6 months later...
Jetexas you just saved me a lot of money. Unplugged it, bam. Drove it home. If I can send you twenty bucks let me know!
Car died a couple times. This time, it wouldn't restart. I unplugged the MAF, started right up.
I take it that means the MAF was the condition causing the problem?
No CEL. 141000 Miles 99 C2.
Ill check if there are any codes asap.
Edited by doublesnaggle
Merci beaucoup, Loren! This newbie knew about IMS, RMS, and even found out about AOS (Air/oil Separator) today, but MAF had eluded me until now. Got a 2000 996 C2 on 25 Apr in Vancouver, BC. At one month away from being 60 years-of-age and having driven VWs all my life, this P-car is very nice, indeed! Cheers!
Martin
