Boxster 1999 2.5 986 idle problem
I have been having problems with this 986 for over 14 months now. So far I have replaced the following:
new MAF
new AOS and all bellows/tubes
new coil packs
cleaned throttle body, ICV and new gaskets
O2 sensor
oil filler pipe (due to a crack)
The problem I still have is erractic idle 800-1000 rpm and a slight misfire. I have followed this forum all this time trying to resolve this problem with suggestions from other users posts
I scanned with durametric and have the following error codes (actual values shown below): Note that I am most concerned about the camshaft errors as these have never shown up until now (from what i have read 6 degrees is valid range and as you can see mine is well beyond this). I still suspect that i have a vacumm leak somewhere as I do hear a howl from the fuel filler on occasions. I am at my witts end now after all this time and any help will be much appreciated.
Motronic 5.2.2
Current Fault Codes
P1124
Factory Fault Code 27 - Oxygen sensing adaptation range 1 (cylinders 1-3)
Enrichment limit
P1126
Factory Fault Code 35 - Oxygen sensing adaptation range 1 (cylinders 4-6)
Enrichment limit
P1531
Factory Fault Code 174 - Camshaft adjustment, bank 1
P0150
Factory Fault Code 18 - Oxygen sensor ahead of catalytic converter (cylinders 4-6)
Short circuit of wires or limited voltage increase
P1340
Factory Fault Code 322 - Timing chain out of position, bank 1
Below lower limit or above upper limit
P1319
Factory Fault Code 62 - Misfire, emission related
P1313
Factory Fault Code 50 - Misfire, cylinder 1, emission related
P1314
Factory Fault Code 51 - Misfire, cylinder 2, emission related
P1315
Factory Fault Code 52 - Misfire, cylinder 3, emission related
P1585
Factory Fault Code 8 - Misfire with empty fuel tank
Below is the Durametric scan actual values (engine cold):
Sensor Value Units
IATS 7.5 ;deg;C
ECTS 42.0 ;deg;C
Ignition timing 6.0 crk
Range 2 Cylinder 1-3 (FRA) 1.01
Range 2 Cylinder 4-6 (FRA2) 1.01
Camshaft position 1 deviation 21.0 crk
Codes 1124 or 1126 could be old or directly related, if cam timing is off signifigantly fuel trims can go out of whack. Most if not all of the codes point towards a problem with a faulty actuator, especially P1531.
Sorry it's not an easy fix. Have a read through these threads for details on the repair:
http://www.renntech....-on-with-p1524/
Edited by logray
"P1531 Factory Fault Code 174 - Camshaft adjustment, bank 1"
"The problem I still have is erractic idle 800-1000 rpm and a slight misfire."
"Camshaft position 1 deviation 21.0 crk"
Definately agree with Loren, clear the codes and see what comes back.
However the above statements lead me to believe they are not going to go away. The poor idle, misfires and timing chain out of whack due to actuator control stuck on. Lots of good info in those links above.
Right, quick update.
I have ohm'd out both solenoids (bank 1 and 2):
bank 1 = 12.5 Ohms
bank 2 = 13.1 Ohms
I also applied 12v directly to each one, both made slight tick noise, tbh I was expecting it to be much louder. Also, I was expecting the bank 1 to not react at all or at least hear a noticable difference between them.
I also checked that 12v is getting to each one with the ignition on, all ok.
Do you think that this suggests a failed actuator? I dont really want to replace the solenoid just to have to go back in again to do the actuator, but on the other hand I dont want to replace the actuator if there is no need especially given the cost!
Any suggestions, do the ohm readings suggest a ba solenoid? Can you service/repair the actuator without replacing it?
Also, I monitored the camshaft deviation for some time, it is dead steady at 23 degrees and never changes.
Cheers
If you activate the solenoid manually and don't hear the engine idle change, then chances are the actuator is toast. The engine should be warm and air conditioning on when you try this. Try both banks to make sure activating the solenoid does in fact change the engine idle.
There is no way to service an actuator, they are sealed/welded units that get "tired". Similarly, you don't want to buy a used actuator because there is no way to know it's condition just by looking at it, unless you are a gambling person.
The 12.5 ohms seems low, normally I see/get around 13 ohms or higher.
Yes if you are going to open the camshaft covers, I would replace actuator and solenoid ($700 USD together) part instead of just the solenoid ($150 USD by itself).
"Also, I monitored the camshaft deviation for some time, it is dead steady at 23 degrees and never changes."
This might be worth a quick sanity check of the current mechanical timing of the car. Perhaps the cam sproket slipped and timing is off and needs to be corrected. Variocam will not actuate if the mechanical timing is off. This can be done relatively easy with engine in car. Details here:
http://986forum.com/forums/showthread.php?t=26418
thanks logray.
I just tried activating the solenoids with the engine running a you suggested. When activating bank 2 idle gets worse however activating bank 1 there is no change. I guess that this confirms that bank 1 actuator has failed in the open position.
With both solenoids disconnected and engine running it did seem to idle better.
Whilst investigating today I have also found that spark plug 5 has an oil leak but i guess that this shouldnt have any effect on the solenoid error being thrown. Also, possibly unrelated I appear to have to top up my coolant every couple of weeks as the light keeps coming on due to being low. I am hoping that I jut created a small leak somewhere when I replaced the oil filler tube a few months ago.
Josellama - were you getting P1531 error code also?
Yes this sounds like a failed actuator to me.
Oil leak in spark plug might cause a mis or slight mis, unrelated to variocam issue.
You might have a leaky hose or coolant tank somewhere. Usually if you get under the car and fish around with a bright torch you can see tell tale "whiteish" fluid/residue from the source of the leak.
Just another thought and probably clutching at straws.
Is there anyway that the solenoid has failed open? Therefore even though it makes a noise it is not actually closing? The low Ohm reading is still bugging me a bit, but maybe this just suggests that this is on its wy out also.
Well either way you have to remove the camshaft cover to replace the solenoid and/or actuator.
So if you are opening up the cam cover, might as well replace both, otherwise if you replace the solenoid and it turns out to be the actuator you have to remove the cam cover again (read, major waste of $$$ on labor).
Guys,
When the variocam solenoid is activated with the car running at idle (with Durametric), the RPM should surge up momentarily& then return to idle. What do you reckon is wrong if, on one bank, the RPM surges but doesn't increase as much as the other (approx. 600RPM vs 1200RPM on good side)??
I am guessing that the variocam system is trying to work but something is stopping the full actuation??!?
Thanks in advance
