For the past 2 months, when I startup the car in the morning it can barely hold an idle; if I try to tap the accelerator it will die; I let it run for about 5 minutes then it seems that it catches itself and the idle jumps up normal; I have tried to turn on AC at startup and it doesnt push up the idle.
No issues after first start for day.
Any suggestions?
