Installing a B&M short shifter in my 1999 996 and have been unable to remove the shifter boot and knob assembly from the original shift lever. I have pulled the boot up towards the knob end as far as it will go and still do not see or feel a set screw as the instructions indicate and even after trying various other twisting, pulling and tugging operations I am still unable to remove the boot and knob. Any ideas short of a razor blade knife would be greatly appreciated.
My 2004-C4S with the sport type shifter has a torx screw almost hiden on the front/lower side of the knob. I still had to pull hard. Not sure about the standard shifter.
Try to slot a large adjustable wrench at the base of the knob (be careful not to mar the knob) and find some leverage to "pry" straight up. When you only grab the knob and pull up, sometimes your hand is squeezing the knob so hard that you're working against yourself since the knob is just friction fit onto the shifter shaft.
Yes, the optional knobs have screws (stated here before) - the standard knobs just pull off.
