  • Similar Content
    • By sullivas
      I was looking for my front end noise problem and I discovered the bolt that attaches the
      lower control arm (wishbone) and holds a horizontal bushing to the crossmember is loose.
      It is 12M x 1.5. About 4" long.
      Given the attached chart should I use 89ft lb or 56ft lb torque?  Also, the face of the nut is kind of shiny from friction,
      I don't know if it was a ribbed type for locking purposes, I don't see any evidence that it was.  The inside
      of the bolt cap is somewhat smooth as well..  Should I replace them with new?
      I hope the looseness of the bolt hasn't rounded out the attachment ears.
      Thanks in advance.
    • By sullivas
      Anyone else have this issue? Whenever I hit a manhole cover or bump I get a thunk/creak (hard to describe)
      coming from the area of the driver's B pillar, seatbelt/pillar/door area. Driving me crazy. I peeled back the weatherstrip
      and put some butyl tape where the plastic side is a little loose but that didn't fix it. The bezel around the seat belt creaks
      when I move it around but I don't think the noise is comig from there. Thanks!
    • By sullivas
      Can anyone explain how the bleeder/purge valve located at the coolant reservoir works and how it should be used? I just did a coolant flush/fill and could use some detail on that valve and getting all air out of the system without an AirLift.
