2002 C4S RMS LEAK Again !
I had a RMS leak (drops of oil) on my 2002 C4S about a month ago. The dealer
replaced both the RMS and the intermediate seals and supposedly performed the test with the seating tool.
The car is back at the dealer again with the same problem.
I wonder if they are going to try to fix it again or if it needs a new engine ?
If it needs a new engine would it be worhwhile upgrading to an X51 engine instead ?
It should cost less on labour since the engine has to come out anyway.
ThunderC4S
Melbourne Australia
Porsche C4S
Arctic Silver
6 Speed Manual
BOSE and Litronics
You're probably right, a RMS should never fail, especially on a low miles car. I've had Chevys and Fords go nearly 100K miles and never had a RMS failure, you can't tell me they are better engineered than a Porsche...then again the CEL has never gone off on my Ford Expedition either.
Edited by dj996
I just got the car back..Apparently they replaced the intermediate shaft seal - the RMS was OK..
Keep in mind both seals were replaced one month ago..
This time around they did not want to give me a printed service sheet detailing the description of the work and the parts replaced..
