Help! Coil separated in engine
2006 V6 Cayenne
I am pulling my coils to change them and the plugs. 4 out of 6 came out normally, 2 separated in the block.
It is deep and don't have any idea how to get the other half out since I can't reach it with a drill bit to tap them.
http://s441.photobucket.com/user/ctwith3/media/image-1.jpg.html
http://s441.photobucket.com/user/ctwith3/media/image-2.jpg.html
Edited by BobbySpeed
The issue you're going to have is the rubber boot inside the metal jacket is going to be "suction cupped" onto the spark plug.
Only though is to get a long hex bolt (the bolt head slightly smaller than the spark plug hole). Put A SMALL AMOUNT of JBweld on the head of the bolt and carefully smoosh it against the broken piece. Let it harden and then carefully twist and turn.
Maybe some of these? GearWrench makes these as pointed needlenose, and a square tip needlenose. As usual, even though made in Taiwan, quality is excellent.
http://ecx.images-amazon.com/images/I/31DepuXVsCL.jpg
These things are pretty awesome, if there's anything to grab on at all, they can exert a lot of grip. They are specifically designed for grabbing something in very tight quarters.
from the pics it looks like it broke flush off....so it may not be possible to grip them with a set of pliers.....especially since the metal portion is so close to the plug wall.
my only question is do you think drilling a hole into them is going to help?
Perhaps you can chip away enough material so you can pry the outer metal shield inward a little at one spot, and give you something to grab on.
Thank you everyone for your help, clarksongli's JB Weld suggestion did the trick. I put an 11/16ths sockets on the bolt on the opposite side of the head of the bolt and packed the socket with paper toweling around the screw to keep it centered in the socket. The 11/16ths socket fits just right in the hole. After about 20 hours I just pulled it straight out with no trouble.
