Lost of power?
Hello all. I have the dreaded codes P0410 and P1411. I plan to track down the problem in the secondary air system. My question to those in the know..Can a problem in the secondary air system result in a lost of power? Thanks!
Side note: I do hear the the secondary pump come on when the car runs great. When check engine light comes on (as it has done several times in the past when I cleared the codes) shortly after start up, I don't hear the secondary air pump come on. The car idles rough with higher rpms as well. Can the fuse for the secondary air pump go bad gradually?
