Secondary air pump
My secondary air injection pump seems to be on the way out. Squealing..and setting off the Check Engine light. I have a couple of questions.
1. Is it too late to take apart the pump and clean/regrease it?
2. Anyone know where I can get a suitable replacement?
Is it the same as a 1999? I see there's a pump for 1999 and then it changes fire model year 2000. With the one from 2000+ work for my 1999?
For a'99, the OE pump is $1k+ eBay has a few used ones $50-75. Maybe worth a try if cleaning/regreasing doesn't work. The squealing is coming from the bearing so I think it's likely regreasing should work. Worst is to press out and replace the bearings.
