I'm wondering if I will get a fault for the fog light when switching out from the halogen bulbs to LEDs. And if so, is there a replacement fog light LED that anyone has used that has a resistor built in or attached that will keep this from happening?
What say you gurus of knowledge?
Hi jsrbrown, I have swapped for LEDs but did swapped for HIDs & I regret it! Constant false errors. Switching back the halogens this weekend
I tried HID's for main beam and the light was much better than standard halogens.  The blurb assured the buyer that that they would be compliant and not generate errors.  However, I did get a few warning light flashes when I used the headlight flasher.  These would stay on until I stopped and turned off the engine.  They disappeared on re-starting.  I have now removed them and put halogens back in.
