How to turn off "check left side marker" warning message
I got the "check left side marker" dashboard warning message two weeks ago. It points to the fault left side marker light. I purchased an OEM bulb and replaced it. The left side marker is working fine now. But I still got the warning message "check left side marker" every time when I turn on the car. A yellow bulb keeps showing up on the dashboard. Does anyone know how to turn off the warning message? Thanks.
Thanks, Loren. I thoroughly cleaned the bulb socket today after reading your suggestion, but the warning message "check left side marker" i still there every time when I turned on the car. Any other advice?
Thank you so much, Loren. Problem solved. It took a little while for the car to detect the cleaned components and remove the warning message. I took the car on a very short drive last night after cleaning the socket as you suggested. The message kept showing up. This morning the message disappeared when I started the car. So far so good. I appreciate your help.
