996 Turbo Front Splitter Screw
I've been scouring all the parts diagrams I can find, but I can't figure out what the appropriate screw / mounting hardware is for the front splitter/spoiler/lip (http://www.sonnenporscheoemparts.com/auto-parts/2002/porsche/911/turbo-trim/3-6l-h6-gas-engine/body-cat/bumper-and-components-front-scat #12). There are two screws in the wheel liner and I'm missing one (see pic)
Is it this? http://www.sonnenporscheoemparts.com/porsche/911/99907306102/2002-year/turbo-trim/3-6l-h6-gas-engine/body-cat/structural-components-and-rails-scat/?part_name=rubber-strip-screw&recommended=1
The parts department ended up giving me a "generic" philips head screw that looks self tapping since the fastener isn't included in any diagrams. They showed me a few 996TTs on the lot that had that screw installed, so I'll give it a shot.
I suspect the plastic rivet would work as well. My friend's 996TT has a different fastener on each side, so clearly this is a bit of an unknown.
Looking at my TT, the plastic rivets hold the splitter to the bottom of the front bumper cover.  That hole has a screw with a washer that matches the shape of the hole in the splitter.  Also of note, it appears your wheel liner is cracked...  The heat really makes it brittle over time.. .I've replaced both my front liners.  it should fit behind the edge of the splitter and the hole in the wheel liner should line up with the hole in the splitter.   Hope this helps...
