Side light
Hi, ive a problem with my drivers side light not working on my 986 Boxster, ive tried 4 different bulbs without success. All the other lights work fine except I had an issue with the indicator flashing really quick as if a bulb had gone before  this problem but then is rectified itself.
It's a 2004 Anniversary model.
Does anybody have any ideas what the problem could be?
Many thanks.
Many thanks.
Have you checked to see if you have voltage at the bulb socket?  If not, you may have a wiring problem.
