LED bulbs for tail lights
  • 6 months later...
On 10/1/2021 at 11:07 AM, JFP in PA said:
Yes, it can be done, but you need to pay attention to potential CAN Bus errors, and you will also need to upgrade to an LED compatible flasher to stop "hyper flash" rates from the turn signals.
Thanks.  How would I find an LED compatible flasher?  Can I assume the "flasher: is a relay that plugs into the fuse box?
