Hello, I found this from another forum, I hope that you can help me:
2002 Boxster S
CDR-220
Model: BE 4462
Serial: Y5039540
EC: 112
Is all that I have on my tag. Is this enough to come up with it?
Thanks in advance,
Paul
Edited by cheetah
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
2002 Boxster S
CDR-220
Model: BE 4462
Serial: Y5039540
EC: 112
Thanks in advance,
Paul
Try 1538
or
1536
Hi I bought MY01 996 last year and I'm not provided with the radio code.
CR-220
Type 4362
Seri 15030796
Thanks in advance.
Try 6609
or
6607
Thanks Loren, unfortunately neither of these code works. I got a "wait" after 3 wrong attempts. I will try 2 digits diff when my sterio is not in "wait" mode.
:thankyou:
I am having the same problem..Dead battery..now no radio.Becker1.. type 4462,serial#x502 1200.IT is in my 1999 2.5 boxter.I would appreciate any help that i can get..thanks!
Try 8578
or
8576
Yet another second owner with no Radio Code!! Any help would be most appreciated!!
2000 S
CDR-220
Becker
Type 4462
Ser # Y5039229
24/99
Thanks!!
Try 11128
or
1130
i have a same problem, please help me...
2001
BECKER CDR 220
type 4462
serial# 15076070
24/99
i've been tried some of code in this thread....i didnt work...thanks b4..
Edited by sammyboy
Hi I recently replaced the battery on my Porsche and as a result I have been unable to use my radio. I have misplaced my radio code and would appreciate your help.
2001 Porsche Boxster Tiptronic
Becker 1
Ser# W5009514
Type 4462
48/98
Becker 1
Ser# W5009514
Type 4462
48/98
Try 7746
or
7744
1856 and 1854 did not work.
I also do not have my 4 digit code.
99 911 c2
CDR 220
BE4462
X5-18556
Ec109
Please help.
Rance
Try 1856
or
1854
Edited by rking03
2001
BECKER CDR 220
type 4462
serial# 15076070
24/99
i've been tried some of code in this thread....they didnt work..
2001
BECKER CDR 220
type 4462
serial# 15076070
24/99
Please read the FAQ - all radio codes are unit to the unit serial number
Try 5523
or
5521
Hello those two codes didn't work. Since that info was on the tag that came with it, I decided that I should see what the radio itself gave me. It is as follows:
Type 4462
Ser. No. Y5039540
24/99
Gal: 00
Does this help any?
Thank you so much,
Paul
2002 Boxster S
CDR-220
Model: BE 4462
Serial: Y5039540
EC: 112
Thanks in advance,
Paul
Try 1538
or
1536
Type 4462
Ser. No. Y5039540
24/99
Gal: 00
Does this help any?
Thank you so much,
Paul
2002 Boxster S
CDR-220
Model: BE 4462
Serial: Y5039540
EC: 112
Thanks in advance,
Paul
Try 1538
or
1536
Please read this and follow the instructions...
:D
HI I have a 1998 Boxster and the radio is a CDR 210 the code is 0651. Hope this helps someone
Peter
Please read the FAQ - each radio is different - so your code can not help anyone.
