  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Hello,
I am looking for a radio code for my 2002 Boxster.
CDR-220
Becker 1
Type: 4462
Serial#: 15087889
24/99
Thanks in advance!
Hello,
CDR-220
Becker 1
Type: 4462
Serial#: 15087889
24/99
Thanks in advance!
Try 2943
or
2941
Neither of those worked. Any other numbers I should try?
Hello,
CDR-220
Becker 1
Type: 4462
Serial#: 15087889
24/99
Thanks in advance!
Try 2943
or
2941
PLEASE read the FAQ.
Looking for a radio code on a:
1999 911
CDR220
4462
X5021000
Thanks in advance
Try 8993
or
8991
Thanks for trying. Followed FAQ instructions and couldn't get it to work. Appreciate your effort!
FYI, it was 9095. I noticed someone else was also + or - 100 and then your 2 digit jumps. Hope this helps.
Help, I need tbe code for a 2000 Boxster S with:
CDR-220 with the Digital Radio option
Serial #: Y5036531
Thank you very much, Greg
Can you please provide the radio code for:
1999 Carrera
CDR-210
PR-VER5 R 3297
T5001403
There is also a long serial # on the back of the removable faceplate. Would that be of any use?
Many thanks!
Craig
Thank you so much for the assistance. 5218 is the code that finally worked. That was plus 102 to your 5116 number.
Thanks again, Greg
