  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hello,
Same old story lost radio code, please help.
2000 Boxster S
CDR-220
Type# 4462
Serial # 15076560
24/99
Thank you in advance
Try 5350
That worked, thank you very much!!
Best Regards
Lonnie
Starting with apologies for putting this at the wrong location at first.
I'd appreciate your help for a similar problem, after à "battery dead".
My radio type is 4467 (CDR 220) with serialnr y5036720.
It's a 2001 boxster 2.7 tipt.
Many thanks, regards, Jos
Ps, hope this is correctly addressed now
Try 4613
Hi Loren, Could help me with a radio code
CRD 210
SN ON BACK OF FACE PLATE IS:228012516272180156
PLEASE HELP
Please READ THE FAQ and obtain the serial number as described in the FAQ.
CRD 210
PLEASE HELP
My Bad
CRD 210
R3297
W5024729
Edited by jgomez
CRD 210
PLEASE HELP
My Bad
CRD 210
R3297
W5024729
Try 5065
CRD 210
PLEASE HELP
My Bad
CRD 210
R3297
W5024729
Try 5065
THANK YOU SO MUCH!!!! it worked inmediately!! :thankyou:
Ok here is another..
So,
Becker 1
CR 220
4362
x5010730
45/98
thanks!
Jammer
Try 2498
YOU my Sir are amazing it worked! High FIVE
Thanks a lot Loren !
It worked just as expected ! ;-)
Got radio again, and a new battery...
I can't imagine how much time you spend answering those requests.
Several codes a day, every day, more than 4500 posts in this thread...
Thank you.
What do you use to get the codes ?
Can't that software be put in a java applet to save you some time ?
-Guillaume
Can you please find my code ?
CR 220 type 4362
Serial Y5023036
Thanks !
Try 8903
Hello everyone , I changed the battery on a 2000 boxter s , now I can't find the code , I called the dealer they would not help me over the phone , They want me to go over there , I know they are gonna try to charge me , If anyone can help me with the code I would very much appreciated.
BECKER
TYPE: CDR 220
MODEL NO: BE 4462
SERIAL NO: X5031908
BECKER
TYPE: CDR 220
MODEL NO: BE 4462
SERIAL NO: X5031908
Try 0901
Loren could you help me with a code?
BECKER
TYPE: CDR 220
MODEL NO: BE 4467
SERIAL NO: X5016400
Try 6901
Thanks alot, it worked and the replay was so fast, Thanks!
