  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Hey , can you help me ????
Its a Becker cd 220 with serial Y5023680
Thanks so much !
Try 4359
It's working.
Thanks a lot !!!!
I need my radio code. Can you help me?
I have a CR 220
serial # is 15085136 or 15086136 / I have a digit that is partially out on the radio.
radio type is 4462 or a 4452 / Again I have a digit that is out.
24/99
Thank you very much for your help.
I have a CR 220
24/99
If the serial is 15085136 -- Try 0642
If the serial is 15086136 -- Try 9637
I have a CR 220
24/99
Try 0642
I have a CR 220
24/99
Thank you so much. It works great!!
I have a CR 220
24/99
Try 0642
Thanks for your help!!
Loren;
Radio is a Becker, Type 4462
Serial #: X5027838
Want to confirm what the previous owner left me on a small piece of paper in the User Manual.
Need to fix my right window's inner door latch tomorrow.
Thanks as always Loren!
Martin
I need the unlock code for my factory radio
Porsche radio serial
X5010826
45/98
Tupe 4362
Gal 00
Thanks in advance
Hello,
I have a 1998 C2S and cannot find my radio code. I'm hoping someone can provide me with my radio code given my radio information below. Any help is appreciated.
Radio model is CDR-210
serial number is V50 15440
Hello, I just want to thank you in advance. your info on how to retrieve the serial number without removing the radio worked great!!! If only the previous owner was as helpful supplying the code :(
cdr-220
type 4462
serial: Y5035267
24/99
cdr-220
type 4462
serial: Y5035267
24/99
Try 9858
