Hi Loren
Thank you for getting back to me. The stereo is now out of my car and I have no code, can I re-connect and press the TP number to find the serial and model?
I'm sorry, I'm not very good at this technical stuff.
Sally x
Yes, follow the procedure in the Lost Radio Code FAQ.
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Hi Loren
Sally x
Thanks again Loren, I'll give it a try ;)
Hi Loren
I followed you steps from the FAQ and now have the details, thank you.
Model no. 4466 Serial no. Y5023203
If you could send me the security code I'd be very grateful.
Regards
Sally
Hi Loren
Regards
Sally
Try 8232
Hi Loren
Regards
Sally
Try 8232
Thank you Loren!
Sorry to bother you again but I've plugged everything back in and it doesn't give me the option to enter my code, it just says WAIT. I've waited a few minutes and still nothing. Do you know if this is normal?
It's a CDR-22.
Hi Loren
Regards
Sally
Try 8232
Thank you Loren!
It's a CDR-22.
PLEASE read the Lost Radio Code FAQ - that is covered there too.
Hi Loren
We need your precious help retreiving my radio code, here the information of my radio:
radio CDR-220
type: 4462
serial: 15001186
thanks a lot!
Nemo!
Hi Loren
radio CDR-220
type: 4462
serial: 15001186
thanks a lot!
Nemo!
Try 8476
No luck with 4643... any suggestions? Here's the info again.
Thanks.
CDR210
r3297
w5023974
If the code I gave you did not work then your serial number is not correct.
Please follow the procedure in the Lost Radio Code FAQ to obtain the correct serial number.
