  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Can anyone help me out? I bought my car used and the battery was flat dead so I installed a new interstate battery now my stereo is locked and I didn't get the owners manual.
Becker cdr220
Be6625
25015434
I live in Newfoundland canada and we don't even have a Porsche dealer
It's a Porsche 996
Becker cdr220
Be6625
25015434
It's a Porsche 996
Try 7363
Hello Loren!
Just got my first Porsche 2 days ago, my dream come true!
I've a 2002 Porsche Boxster with 72000 miles.
I changed the battery and don't have the radio code... could you yelp me?!
Radio: CDR 220
Type: 4462
Serial #: 15002406
Thank you in advance and happy father day!
Gregory
Hello Loren!
Radio: CDR 220
Type: 4462
Serial #: 15002406
Gregory
Try 0790
Hi all
im in the same boat ,but its my sat nav code on my 1999 carrera ,i have the code card and porsche say it the right one but it locks me out,the serial number on the card doesnt match the one one on the unit.
its a seimens unit serial number PO221014T724L
Any help would be appreaciated.
Hi all
Please read the Lost Radio Code FAQ....
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Thanks for getting back
but it doesn`t help,like i said i have the original card with code and the previous owner assures me the has never changed the nav system
any more ideas ?
Andy.
any more ideas ?
Andy.
And this is the Lost Radio Code thread -- you need to post in the appropriate forum please.
I'm needing the code to restart my radio in my '97 Boxter. The radio/cdr serial number is V5008478. Can anybody help me?
Also, and definitely secondary, I can't get the cd player to play; it accepts (and ejects) the cd but nothing else. Any clues?
If needed, the model # is R2896.
Thanks so much!
Thanks so much!
Try 7649
Thanks so much!
Try 7649
I tried it, but the 7 begins to flash after a few seconds and nothing else happens. Do I need to do anything other than punch in the numbers?
Thanks so much!
Try 7649
What is the exact model name on the front of the radio?
It should start with "PORSCHE xxx-xxx" where xxx-xxx is the model number.
Thanks so much!
Try 7649
It's a CDR 210
Thanks so much!
Try 7649
It's a CDR 210
Please read the Lost Radio Code FAQ for the procedure.
