3 hours ago, nomansland92 said:
Hey Loren
Could you help my with a radio code?  I disconnected the battery while working on the car and now I cant find the code anywhere.
CDR-220
Type 4462
Serial 15065035
Thanks I appreciate the help!
Try 5435
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Hi Loren, you've become quite a legend, to be honest. 725 pages of helping people. Impressive.
Here is my code request for my new 996 4S 🙂
CDR-220
Type 4462
Serial 25014042
Thanks!!! Also no need to remove the radio, I used the 10-second hold TP button + scrolling right.
Edited by Oscar Bencomo
CDR-220
Type 4462
Serial 25014042
Try 8761
  • Like 1
Can you help with mine please? TIA!
2002 996
CR-220
Serial # Y5022195
Edited by Jrat36
23 minutes ago, ViolinARC said:
Hi...need the code for my Becker Nav. TIA :cheers:20231030_152540.thumb.jpg.8ff514496b45bdfe06024aea5eb1d361.jpg
From the Lost Radio Code FAQ....
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Thanks Loren! Bummer, I was excited until I read your referenced thread. The "Stealer" wants $300 to "code" the PCM...UGH! Guess an aftermarket HU is worth it since I can get one for the same price as the hour labor for this old, outdated unit.
Thanks again for your quick response and for helping sooooo many others. You rock! :clapping:
About to swap battery and hoping to get ahead of a radio issue. Help would be greatly appreciated.
Becker 1
type 4466
Serial: X5844535
Becker 1
type 4466
Serial: X5844535
Try 6530
