  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Need help getting a code too. Here's our info.
Becker 1
Type: 4462
Serial# Y5038582
24/99
2001 Boxster base
Thanks much
If the code works, what happens? Does the radio work right away?
I tried both codes and it doesn't seem to have worked. Even got the "wait" code and had to wait an hour. Tried the codes again and keep getting prompted to enter again.
How many times should you enter the code?
Thanks for the help.
Becker 1
Type: 4462
Serial# Y5038582
24/99
2001 Boxster base
Thanks much
PLEASE - read the FAQ.
Can you please provide the radio code for:
1999 Carrera
CDR-210
PR-VER5 R 3297
T5001403
There is also a long serial # on the back of the removable faceplate. Would that be of any use?
Many thanks!
Craig
Try 0954
or
0952
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Awesome!! The plus two trick worked, kicking in at 0956. And, inexplicably, my FM started working again. THANK YOU!
Hi Loren,
2002 996 Turbo
Porsche PCM with NAV
The battery ran down when it was in the garage over winter.
Can you help with this unit? I don't know how to get the serial number from it. There is no TP button.
Hi Loren,
2002 996 Turbo
From the Lost Radio Code FAQ
Can you give me a code for my PCM (or Traffic Pro)?
Sorry, the only place you can get a PCM (or Traffic Pro) code is from a dealer/OPC.
New to this Forum. I just got my 1999 Boxster out from winter storage, and the battery was dead. Now the radio wants a
four digit code. The radio is a CDR-220, type is 4462 and serial number is Y5061126. The first letter may be an X, my
display isn't 100%. Hopefully you can help me. Thanks in advance.
Try 4402
or
4400
Hay guys i have a new toy a Boxster 2001 triptronic disconect a battery a good bye radio , in mi country not have a dealer for help me , thanks for your help info TYPE 4462 - DCP2081 - serial X5033377
Try 6782
or
6780
NOT WORKING ......SNIFFF OTJER POSSIBILITITY
PLEASE - read teh FAQ.
Becker 1
Type: 4462
Serial# Y5038582
24/99
2001 Boxster base
Thanks much
Follow the instructions in the FAQ. Still didn't work.
I called the dealer and obtained a code from them as well. Still didn't work.
Seems if no codes work on the radio, then the radio itself, per the dealer, is defective.
So, looks like I need to replace my CDR 220.
Thanks for the previous help and posting of the FAQ.
Becker 1
Type: 4462
Serial# Y5038582
24/99
2001 Boxster base
Thanks much
Did you get the serial number through the radio display?
Many times a tech changes out a radio and forget to change the code ID card too.
Becker 1
Type: 4462
Serial# Y5038582
24/99
2001 Boxster base
Thanks much
Yes, I got the serial via the radio display. Followed the instructions on the FAQ =)
Try 4402
or
4400
Thanks, Loren. Worked like a charm.
Hi, Loren. Same problem. Firt start after winter storage and dead battery on my 2001 Boxter. Becker 1 radio, type 4462 Ser# Y5052643. Also displays 24/99 and CDP2081.
Manny
Manny
Try 4253
or
4251
Thanks for the quick response, Loren. It was 4253. You rock!
Manny
Hello Loren,
Can you please provide the code for my radio.
Thanks in advance for the quick response.
CDR-220
Becker
Type 4462
Ser # Y5042949
24/99
Hi Lauren,
I have a 97 Boxter and am looking for radio code Model R2896 Serial V5006924. CDR210
Any help is greatly appreciated.
