  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Hi, this is the second time I've replaced the battery in 2000 Boxster. The first time the unlock code (0189) worked fine. This time though, I cannot even get the radio to power on! I tried holding down the power key for a few minutes and nothing! Help-how do I get the radio to turn on? Thanks so much!
Please post radio problems in another thread - this thread is for lost codes only.
Check the fuse on the fuse panel and the fuse on the back of the radio.
thanks sorry it took so long to reply niether code work over the past few days been tryng to #s higher each time but no luck off to the dealers thanks again dan
hello
My battery died over the winter
and cant find my radio code
maybe someone would be kind enough to help
becker cdr-220
type:4462
serie:x5033124
48/98
thanks in advance
dan
Try 0422
or
0420
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
I changed the battery and also need a code for my radio. Can you please help me?
Type 4462
ser# X5032710
not sure what the 48/98 means
Also when I changed the battery, the airbag light is now on. Any suggestions on that?
Thanks for your help.
Rick
Type 4462
ser# X5032710
Rick
Try 8373
or
8371
I have a 2002 C2 Cab tiptronic US and I had to disconnect the battery. I tried to enter the code that was listed when I used my Durametric software. The code displayed was 1024 and that did not work.
I have the Becker CDR220
4462
15004937
Any help would be appreciated.
Bosco
4462
15004937
Bosco
Try 1065
or
1063
4462
15004937
Bosco
Try 1065
or
1063
Thanks for the fast response. The codes I entered didn't work (1065 or 1063). At the enter code prompt all I should do is enter the 4 digit number 1 time or am I doing the procedure wrong? I did try to enter 1065 then the enter code prompt came back and I entered 1063 and the enter code prompt came back again and I entered 1065. The WAIT message appeared after 3 attempts to enter the code.
Thanks again,
Bosco
4462
15004937
Bosco
Try 1065
or
1063
Thanks again,
Bosco
Did you read the FAQ?
I have a 2001 Carrera 4 with a CR220 my battery was change and now I do not have the code...can you help me? If so, pleae email me the code... My serial number is X471355. Thank you...
Hi, a request from England.
Got my Boxster 986 2001 out of the local garage (they fixed some electrical issues), and the radio was reset. As I bought the car second-hand, I was never given the code, so now I am stuck.
Following your instructions I got the following:
Porsche CDR-22
Becker 1
Type 4467
Serial Y5035863
Your help with the code is really appreciated.
