Hello Loren,
Can you check this code again? The 4497/4495 did not work. I also tried 4493 4491 4499 4501 as you suggested (up by 2).
2000 Boxster 2.7
5 speed manual
US = LHD
Becker 1
CDR220/CR220
Type 4462
Serial y5040626
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Hello Loren,
2000 Boxster 2.7
5 speed manual
US = LHD
Becker 1
CDR220/CR220
Type 4462
Serial y5040626
Hello John
Thanks for your feedback
Now try code 5497
Please let me know how you get on...
Your feedback is appreciated regardless
Cheers.
Need Radio Code:
1997 Boxster 2.5
CDR-21
Model # BE 2280
Serial # V5011853
Thanks a lot.
Try 6875
or
6873
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Thanks for the quick answer, but it doesn't work.
I've checked the Model & Serial No. another time, they're right.
What can i do?
I've forgot to say that the car is currently in germany, but it's from US
(5 speed manual)
Thank You
Edited by PorscheGermany
Need Radio Code:
1997 Boxster 2.5
CDR-21
Model # BE 2280
Serial # V5011853
Thanks a lot.
Try 6875
or
6873
What can i do?
(5 speed manual)
Thank You
Just checked,
you're not far off..
Use code 6876
Let me know how you get on....
Cheers.
Need Radio Code:
1997 Boxster 2.5
CDR-21
Model # BE 2280
Serial # V5011853
Thanks a lot.
Try 6875
or
6873
What can i do?
(5 speed manual)
Thank You
Just checked,
Use code 6876
Cheers.
I love you :drive: :thankyou: :thankyou:
I haven't found many requests for the Nav radio code. Is is possible to get the code through this post? Is there a any scan tool available that can retrieve this code and if so which controller does the code reside?
Becker 2582
Type: IDIS
Serial No.: Y5007717
Becker 2582
Type: IDIS
From the FAQ...
"Can you give me a code for my PCM (or Traffic Pro)?
Sorry, the only place you can get a PCM (or Traffic Pro) code is from a dealer/OPC."
Got one for a MY 99' I am trying to figure out..
Tp. Pcm
Mod BE 2562
Ser X5008164
Anyone?
TIA!
With all due respect, your question has been answered in the
previous post, and in the FAQ post.
However, I'll offer some advice for your benefit and the
community.
Although I haven't seen BE2562 specifically, it belongs to the
range of navigation systems BE2560, BE2580 and BE2582. These
units are all manufactured jointly between Becker and Siemens
These units require two codes. The first one requested is the
Siemans code, to unlock Sieman's protection. The second code
requested, unlocks Beckers protection. You will notice two
serial numbers on the unit - Siemens and Becker.
Only Porsche, Alfa Romeo and Lancia have access to the Siemans codes
based on Siemens serial number. Access to this database is not
available from any other source.
So, the best advice is to contact Porsche, where they will provide
both the Siemens code and the Becker code.
I'm saying all this, because I've heard of these units being
unintentionally LOCKED through owners entering
multiple Becker codes for the first code requested. In this
situation it may be very difficult for the main dealer to help
you, or at least very expensive.
So the short answer is... contact Porsche. And the long answer
............is still the same
Cheers.
Hi Loren,
I have tried your two codes 6754,6752 and also 6756 6758 6750 6753.
It doesn't work.
Have you an other proposal?
Patrick
I haven't the radio code of my new car 996 carrera 2 01/2000 (black)
Becker 1
type 4467
# X5021326
24/99
Many thanks in advance
Patrick
Try
6754
or
6752
Hi Loren,
It doesn't work.
Patrick
Becker 1
type 4467
# X5021326
24/99
Patrick
Try
6754
or
6752
PLEASE read the FAQ.
Becker 1
type 4467
# X5021326
24/99
Patrick
Hi Patrick
Just looked it up.
Try code 6765
Cheers.
Edited by Bruce2010
Becker 1
type 4467
# X5021326
24/99
Patrick
Hi Patrick
Just looked it up.
Try code 6765
Cheers.
Bingo! the good code
Many many Thanks Bruce
Hey Patrick
You're very welcome.
It may interest you to know, that fellow member c377cc 's
code was also 6765 - three pages back.
(How's that for a coincidence?)
Cheers.
Going to have some work done that may involve disconnecting the battery, I think it maybe a good idea to have it just in case.
My serial number is WSO18669, thank you ahead of time. Oh, and it's a Becker CDR-210.
Try 9928
or
9926
Okay, I just recently disconnected the battery, and after reconnecting, I tried both of those and they don't work, perhaps my serial number is actually W5018669? Would that yield different results? The digital display makes it weird to decipher the serial number. Again, thanks in advance!
Try 9928
or
9926
Get the real serial number using the procedure in the FAQ.
I need the radio unlock code for my CDR-220.
Serial number is 15064158
Thanks for your help!
Hello Indydave
Use code 2108
let me know of your success.
Cheers.
