  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
1998 Boxster
CDR-210
s/n 226012516272081353
thanks!
Is this the serial number appearing on the display,
after following instructions here?
It appears that you have a Becker barcode for the BE2260. However,
Becker barcodes are normally 15 digits long, also including letters.
(In saying that, I haven't physically seen a BE2260's label)
If you have removed the radio from the dash, quote the :-
Model Number: eg BE 2260
and
the 8 digit alphanumeric serial number, eg. 15006256 or V5001245
from the label.
Just need to make sure got correct serial number.
Cheers.
1998 Boxster
CDR-210
thanks!
and
from the label.
Cheers.
I did not remove the entire radio, just the faceplate. that long number was on a sticker behind the nameplate. I don't have any other numbers.
also, I could not follow any of the instructions for finding the number by pressing a series of buttons. my cdr-210 has no knobs or TP button.
1998 Boxster
CDR-210
thanks!
http://www.renntech....radio-code-faq/
and
from the label.
Cheers.
CR-210:
Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of numbered buttons below display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
Or, if the radio is out of the car the then the serial number is on the label.
1998 Boxster
CDR-210
thanks!
and
from the label.
Cheers.
CR-210:
I tried to do this & nothing happened. I will try again. do I continue to hold down the tone button when & press 8 & 0 simutaneously.
ok, let's start fresh - I was able to get info from my radio. to refresh:
1998 Boxster
CDR-210
R2896
s/n V5007975
thanks!!
1998 Boxster
CDR-210
R2896
s/n V5007975
thanks!!
Gotcha! ...........................7216
hi loren , same problem ,no code
CDR-220
Becker
Type 4462
Ser 25013203
24/99
thanks in advance
Try 8222
or
8220
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Hi Loren ,
thanks for your quick reply but it didn't work!
i had already tried 3 times other codes , and then when i found out i was gonna wait for one hour to have the "wait" disappear ,i drove the car for 15 mn and than there was the code stars i tried 8222 & 8220 nothing happened should i try them one more time or what?
thanks for all the help i really appreciate it!
CDR-220
Becker
Type 4462
Ser 25013203
24/99
thanks in advance
Try 8222
or
8220
Hi Loren ,
Try 8232 ...................
Just got this car a few months ago and now I need the radio code please!
2001 S
CR-220
Type 4362
SN: Y5023403
THANKS!!
Try 0576
let me know how you get on...
Cheers.
Hello.
Helping a friend with his Boxster 1997 ( manuel gearbox, ROW )with a CDR21 radio with no code.
The radio have been changed sometimes ago by previous owner but here a the numbers that I got from the radio.
CDR-21
Type : BE2280
SN : V5011627
Looking forward for your answer.
Thanks !
Hello.
CDR-21
Type : BE2280
SN : V5011627
Thanks !
Try code 4315
I lost the code for my Radio. Any help would be appreciated. Thanks
CDR-220
Becker 1
type 4462
# 15063993
24/99
Edited by jrnicl9
Thanks!!! the code works.
CDR-220
Becker 1
type 4462
# 15063993
24/99
Use code 4785
I've been radioless since battery recharge. Hopefully, you can help. RH Drive 2.7 2000 Boxster.
Becker 1
4367
X50 18606
49/98
Try 5842
let me know how you get on....
Cheers.
Hi - after an IMS bearing replacement my radio is now requesting a code...can you help ?
CR22 Becker 1 / Type 4367 / Serial Number Y502 1907
Many Thanks !!!
