Becker 1
4462
x5036895
Try 3182
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Entered the wrong code 3 times (not the one you sent) and now it says Wait... so I can't try your code... know how I can reset the Wait?
Hi RapidMark
Your radio is time locked, through entering the code incorrectly three times.
You need to turn your ignition key to the accessory position (battery light showing in dash), and
power the radio ON, and leave undisturbed, without touching any buttons, otherwise the timer just
resets from the beginning.
Time required to reset is typically one hour.
When reset 'CODE' will again display, allowing you to enter another code.
Any problems, let me know how you get on.
worked Great!!!!
Thanks.
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
New to me 1999 Boxster with CDR 220, PO did not have radio code.
Type: 4462
Ser: Y5048887
Your help is much appreciated.
Joost
Try 9657 ...........
Type: 4462
Ser: Y5048887
Joost
WOW, that was quick. And yess.. it worked.
JP
Seems I have fallen into the same trap....diconnected battery in 1999 911 cab and now need radio code
got info of
r3297
V5009207
any help would be greatly appreciated! thanks!
Hi I need a radio code...
Becker1
CDR 220
4462
Y5061023
Incidentally, my DME reader is giving me a code of 8960 - which does not work.
Thanks in advance!
Becker1
CDR 220
4462
Y5061023
Thanks in advance!
Try 9179 ................
Hi Loren! Been a member for quite sometime now and this website has been a tremendous help. Recently bought a 2000 996 C2 with 97K miles on the chassis, 38k miles on a reman engine which was installed ~4 years ago. No books /manual when bought. Need help with Becker CDR 220.
Type: 4462
Serial: Y5036259
Thank you much!
Type: 4462
Serial: Y5036259
Thank you much!
Try 5020
Hi Lorne,
Would you be able to get me the code for:
CDR220
Type 4462
Serial 25016942
The dealer gave me 8435 but it didn't work.
Cheer!
Chris
Try 7142 .........
let us know how you get on.
Cheers.
Worked perfect!
Thank you so much!
Hi Lorne,
CDR220
Type 4462
Serial 25016942
Cheer!
Chris
Try 7142 .........
Cheers.
Hi, I changed my battery and need a code. Previous owner had written "radio code 2621" in the manual, but that does not work.
cr-220
becker1
type 4362
serial W5002454
Thank you very much!
