  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hope someone can help, had to change battery on bolster, don't have radio code Becker Type4467 Serial numb X5016568 Many thang in anticipation
Try 5414
2002 Boxster S I entered a number that I thought might be the code, tried it several times, but wasn't, now it just says wait. I don't know what the right code is. Should I disconnect the battery again and start over?
model cr 220
type 4362
serial # 15004363
thanks for your help. This is really a cool service.
Hi, I hope someone can help. I just had a new alternator fitted and they disconnected the battery and now I have lost the radio code for my Boxster S. Any help would be appreciated.
Can you please give me the correct code for activation
Becker 1Type 4467# P500698424/99
Thanks in advance
model cr 220
type 4362
serial # 15004363
Try 6985
Thanks in advance
Try 1063
Try 5414
Many thanx worked a treat, excellent & speedy response
model cr 220
type 4362
serial # 15004363
Try 6985
Loren, you rock. I just waited a while with the ignition and radio on and it let me try your code- voila! Thank you again
Thank u for the quick reply and for your time but tried and didnt worked...
Then you likely did not perform the the serial number display (per the FAQ) correctly - or transposed the numbers.
If you want to check I'll rerun your serial number again.
now im clear i did a mistake while givin you the type is cdr 22 and not 220 !!! sorry , and hope you can help me now...thanks man !
If you read the FAQ there is an easy way to show the serial number through the display...
though it was the same , now i saw that it was becker 1 , Type 4467 , serial 25005710,thank you
You need to check and see if it is the same.
This is the third time I have asked you.
i checked it to the display the serial was the same just the type was 4467 not cdr 22 ! so to the display it says type 4467 and serial 25005710
Then 4723 should work.
