  • Replies 18.9k
  • Created
  • Last Reply
Top Posters In This Topic
Hey Loren,
I searched thru other post but could not find a solution.
Radio Code Issue after battery replacement:
2002 C4S
Becker1
4362
#15004153
24/99
Problem is...radio only says "MUTE" and does not ask for a code...which I don't have anyway..
It allowed me to get SN's and radio type after holding TP but then returns to MUTE when radio is turned OFF and ON...
Any suggestion?
Thanks a million!
jon
Hey Loren,
2002 C4S
Becker1
4362
#15004153
24/99
Any suggestion?
Thanks a million!
jon
Did you try pushing the volume button? that turns mute on and off.
For your code
try 0968
or
0966
Hey Loren,
2002 C4S
Becker1
4362
#15004153
24/99
Any suggestion?
Thanks a million!
jon
For your code
try 0968
or
0966
Thanks Loren for the suggestion.....It was not the MUTE switch....
When I replaced the battery...I was hoping that if I R & R'd the Battery quickly enough with the help of another person (<30 sec), maybe there would be enough capacitive charge or luck to avoid the radio code issue....
I'm not sure what happened but looks like the radio "locked up" in "MUTE" mode.....Volume/Mute switch would not toggle between Mute and Volume states.
At any rate, I re-disconnected the battery, waited 60 sec's and reconnected.
The radio then asked for the codes, I entered and everything is back to normal.....
Many thanks....
I suppose the radio locked up with my initial quick battery change.
It would not go out of MUTE display initially no matter what I did.
jon :D
Loren -
2001 Carrera 4
Type: CDR220-Cassette
Mod: 4362
SN: 15040443
24/99
Thanks - this is a huge convenience!
Try 5048
or
5046
Loren - these don't seem to work. I checked the serial # again and it is correct. Is there another code(s) I should try?
Loren,
Great job on the site. I've read some many of your posts. I've run into the same dead battery issue. So after having all that fun looking for the hood release without jacking up the car, I now need the code for the radio. Much thanks in advance.
2000 996 C2
CDR-220 CD
Ser# Y5035648
Type 4462
24/99
Loren,
2000 996 C2
CDR-220 CD
Ser# Y5035648
Type 4462
24/99
Try 0643
or
0641
Radio Code Required, Please if you can, for Becker1 4462, W5006333, 30/98. Thanks in advance and Best Regards, Kris.
Loren,
2000 996 C2
CDR-220 CD
Ser# Y5035648
Type 4462
24/99
Try 0643
or
0641
It worked perfectly. Thanks again.
99 996 C4
CRD 220
T 4462
S X5017980
Lost card and checked under the hood on the sticker - no code.
Thanks in advance!
Try 7255
or
7253
7256 worked, thanks!
Dear Loren,
I noticed your helpfulness torwards other members on their request for the reset codes I hope that you might be inclined to help me too? :)
Becker
type: CCR 220
Model: BE 6624
Serial: 15002956
I miss my tunes ;)
Thanks in advance
-Monica Baligad
Dear Loren,
Becker
type: CCR 220
Model: BE 6624
Serial: 15002956
I miss my tunes ;)
Thanks in advance
-Monica Baligad
Try 4677
or
4675
Please help with radio code. Becker 1, Type 4462, Serial 15001759.
Try 2539
or
2537
I tried those two codes as well as 2533, 2535, 2538, 2541, all no luck.
I actually have a 996, not a 986. But I don't think it should matter.
I will try a few more combinations tomorrow night (three wrong inputs and I have to wait an hour before I can try another three times), but I might be in the unlucky 5% where the program doesn't work :(
Thanks anyway! :renntech:
Edited by Galun
I too, have lost my radio code. Pertinent info is :
Becker model CDR 220 from a 2001 Boxster S
Model #Be 4462
SN Y5050621
Any help would be greatly appreciated, Loren
