I too, have lost my radio code. Pertinent info is :
Becker model CDR 220 from a 2001 Boxster S
Model #Be 4462
SN Y5050621
Any help would be greatly appreciated, Loren
Try 4457
or
4455
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Loren,
Which radios does your program support? I just purchased a 2000 Boxster with an aftermarket Eclipse stero that I am not fond of. I want a factory radio. Which is the best factory unit that is supported by your program, as I am looking to buy one off of ebay.
Thank you
Sean
For a 2000 Boxster the best you can do in factory radios is the CDR-220.
All the 986 series (and 996 series) radios are made for Porsche by Becker.
None are very good - but if you want OEM go with the CDR-220.
Thank you for the input, looks like they are pretty cheap on ebay too.
Model #Be 4462
SN Y5050621
Try 4457
or
4455
neither number worked....any other suggestions, Loren?
I apologize for the multiple postings. I hope I am posting this in the correct location. I am the second owner of a 99 Boxster. I had to replace the fuel pump. This obviously required the battery to be disconnected. I was not aware of the radio code required. The information from the radio is below.
CDR-220
Becker 1
Serial Number: W5011278
48/98
Any help would be greatly appreciated.
CDR-220
Becker 1
48/98
Try 2786
or
2784
Hi I need help with my radio the baterry went dead and now I need a code can any one help i have a 1998 boxster 2.5 and the radio is a cdr 210 dont know where i can get the seario# please help thanks
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Hello again ok i try to get the serio# all i got was this i hope this works 228012516272082561 I have a cdr210 on a 5speed boxster 1998 2.5 gray interier thanks again for the help
CDR-220
Becker 1
48/98
Try 2786
or
2784
Loren,
Thank you very much for the help. Neither 2784 or 2786 worked but 2787 did. It is great to have the radio back.
Now this happened to me as well! I've been dying to post my serial and info in order to try to get a code, but just couldn't find a way to get it. Iit seemed much harder to find info on how to find the serial on the CR-210 without yanking the radio out, as opposed to the other models... I finally did and here is the info on how to retrieve the model and serial:
"For the CR-210:
To get serial #, press tone, then 8&0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of numbered buttons below display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
NOTE: When you get the number from your friendly dealer, (he gave me mine free) and you enter it in place of C O D E, the first number will blink as if your number is wrong. Press the station up arrow on the right to go to a station. Voila!"
Hope this helps others out.
Here's my info:
Cr-210
Becker
model: R 1996
Serial Number: V5004262
thank you very much for any help.
Joe
"For the CR-210:
Here's my info:
Cr-210
Becker
model: R 1996
Joe
Thank you for the CR-210 info - I have added it to the FAQ here.
For your code try 9008
or
9006
"For the CR-210:
Here's my info:
Cr-210
Becker
model: R 1996
Joe
or
9006
wow, thanks for posting so quickly Loren. Unfortunately, 9006 and 9008 didn't work... I threw in 9010 just for giggles and no go as well.
Hi - hoping you can help - I stored my 996 for the winter and the battery died :( Can not find the code, info is as follows:
Becker
4462
Ser: 15004949
Any assistance would be great!
Becker
4462
Ser: 15004949
Try 1161
or
1159
"For the CR-210:
Here's my info:
Cr-210
Becker
model: R 1996
Joe
or
9006
amazing, my dealer says that I have to actually bring the car in to get the code!
Becker
4462
Ser: 15004949
Try 1161
or
1159
Thanks for the quick reply but neither of those worked - any other suggestions?
Becker
4462
Ser: 15004949
Try 1161
or
1159
i had the same issue...looks like we fall into that unlucky 5%. It didn't work out for me, but maybe you could try calling the dealer?
"For the CR-210:
Here's my info:
Cr-210
Becker
model: R 1996
Joe
or
9006
hey Loren, so was my actual number 9008 or 9006?
"For the CR-210:
Here's my info:
Cr-210
Becker
model: R 1996
Joe
or
9006
The programs response to your serial number was 9008.
But history has told us that the program is sometimes off by 2 numbers. More recently we have see it be off a few numbers.
"For the CR-210:
Here's my info:
Cr-210
Becker
model: R 1996
Joe
or
9006
Thank you again Loren, so far I've tried 9004, 9006, 9008, 9010, 9012...and have been locked out with "wait" once, but if I leave the key on for an hour, it goes away and I get to try again. One more try and it's another hour, but maybe I'll go for 9014 :) Is it ever off by ones instead of twos?
ok I finaly found the serio for my stereo cdr210 yeah ok here its (V5015733) if any one has the code for this radio please help thanks for any help
