  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
The method mentioned in the link is what I used to get that serial number. I confirmed X5029187 is the correct number. Any suggestions with how I can acquire the code? Will I need to go to the manufacturer?
Sorry - when it come back as invalid S/N - there is nothing I can do.
You will need to contact Becker Autosound in your country.
I did contact Becker Autosound in New Jersey and they were able to provide me the code, at a price of course.
Thanks for your efforts!
HELLO, JUST REPLACED BATTERY IN 1999 PORSCHE BOXSTER AND AM SEEKING CODE FOR STEREO. BECKER 4462, SERIAL NUMBER X5021159,....THERE ARE ALSO MYSTERY DIGITS , I HAVE NOT SEEN EXPLAINED HERE (48/98).THANKING YOU IN IN ADVANCE FOR YOUR KIND ATTENTION. DONNA
Try 8250
THANKS LOREN, YOU GIVE GOOD RADIO. WORKED LIKE A CHARM. I KEPT THE CODE CARD IN MY WALLET FOR 15 YEARS, AND NEVER ONCE REFERRED TO IT. I FILED IT WITH IMPORTANT CAR DOCS WHICH ARE OUT OF REACH AT THE MOMENT, SO YOU HAVE MADE MY DAY! IF I MAY ASK A QUESTION, WHAT IS ( GAL 1 ) IN THE TP INFO SEQUENCE? AND IS THE (48/98) THE 48TH CAR MADE IN 1998? THANKS AGAIN.
You can download the CDR-220 Owners Manual here
It explains all of the functions of the radio.
This thread is for Lost Radio Codes - so if you have other questions please post them in the appropriate forum. Thank you.
Hi I have boxster model 2000 I need the radio code if anyone can help CR 220 Serial x5019674 type 4362
thanks in advance
Edited by Hash
Trying to retrieve my CR 210 radio code. I have a 1996 Carrerra 4S. The serial number on the unit is:
213011830952454021. Any help would be greatly appreciated.
Mattmel
Mattmel
Try 5109
Hello ,
I need the code for a1999 996 Carrera 4.
It´s an PCM Becker : Typ Idis, Modell 2580 Serial Nr. 15059254.
Can you help me ???
Please read the Lost Radio Code FAQ
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM?s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Mattmel
Try 5109
Dear Loren would you help me to find my radio code please
