  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
I am missing the code to my radio.  Any help would definitely be appreciated.
Radio type is 4462
s/n: 15086415
Thank you,
Adam
Radio type is 4462
s/n: 15086415
Thank you,
Adam
Try 7021
I'm Porsche newbie. graduated from Mercedes. I swapped out my batter on my 99 boxster and now i need a code. I've following a few threads and looks like i can get some hlep from you nice porsche owners.
Here's the radio info i got.
Ser# W5022344
Type 3297
Ser# W5022344
Type 3297
Try 6709
4 hours ago, mikederge said:
Just changed my battery and don't have code for 97 Boxster
CR210 V5004873  850276
Thanks in advance
Usually there are no spaces in serial numbers.
If your serial number is: V5004873
Try 6970
If your serial number is: V5004873  850276
Try 6545
  • Like 1
2 hours ago, Loren said:
Did you follow the procedure to get the correct serial in the Lost Radio Code FAQ?
I sure did. Was going to send picture of the ser # I grabbed from the radio after accessing the ser # menu area. but file size was to large. I def have the ser # correct. No worries though. Thanks for trying.
Try 4685 (I may have made a typo)
2 hours ago, Calvin Goldschmidt said:
Sorry. Still not working. Again, I appreciate you trying.
Well then chances are that your radio has been repaired by a 3rd party (not Becker).
In that case I am sorry I can not help.
29 minutes ago, MechanicalEng said:
Hi Loren, could you please find my code?
CR220
Type 4362
Serial# 15031464
Thank you so much!
Try 5028
Hello,
I have the same problem, I wasn't aware of the unlock codes for the radio when I changed the battery.
Becker CDR - 22
type  4467
serial # 15055546
Thanks for your help ?
Next time, I will keep the maintainer on the battery when I change it.
Becker CR-220
Type 4362
serial #  15004875
Thank you!
Edited by alfonse
11 hours ago, Yorkshire Paul said:
Hello,
Becker CDR - 22
type  4467
serial # 15055546
Try 5428
  • Like 1
