CDR22
Type 4467
Ser Y5028991
24 99
TIA
W
Try 7657
or
7655
Thanks for that Loren. Tried both with no luck. Just waiting for the 60 minutes to expire to try the '2 rule'. Many thanks for all your help - you really are #1...
W
No luck. Tried 7653, 7655, 7657, 7659 and 7661. Oh well, never mind! Thanks for trying Loren, much appreciated! Does it matter to where the radio/car is shipped? I'm in the UK.
W
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
CDR22
Type 4467
Ser Y5028991
24 99
TIA
W
Try 7657
or
7655
W
W
No, country does not matter if it works then it works if it doesn't then it doesn't.
You did get the serial number from the FAQ procedure not off a card in the car?
CDR22
Type 4467
Ser Y5028991
24 99
TIA
W
Try 7657
or
7655
W
W
Got the serial number by pressing TP for 10 seconds then turning the right hand knob as per your earlier instructions...
W
CDR22
Type 4467
Ser Y5028991
24 99
TIA
W
Try 7657
or
7655
W
W
W
Then you can try the other things in the FAQ.
CDR22
Type 4467
Ser Y5028991
24 99
TIA
W
Try 7657
or
7655
W
W
W
Would you believe it was 7658?
Many thanks for trying and getting so close.
Kind regards
W
thanks for the quick response. sadly those codes did not work.....so I am SOL.
Guess I will try the dealer
Thank you again you are the best
PR
Hi Loren,
Could you kindly assist me with my CDR 220 radio code please. I had to replace my battery today and my radio needs the code.
My details are:
Type: 4467
Serial #: Y5022454
Thanks in advance for any help you can provide
Gary
'00 BoxsterS
Hi Loren,
My details are:
Type: 4467
Serial #: Y5022454
Gary
'00 BoxsterS
Try 4756
or
4754
Hi, a request for:
CDR-220
Type: 4462
Serial: X5032056
Thanks in advance,
Shane.
Try 0068
or
0066
Unfortunately they did not seem to work; any other suggestions apart from the 2 digits either side as suggested in the FAQ?
Hi, a request for:
CDR-220
Type: 4462
Serial: X5032056
Thanks in advance,
Shane.
Try 0068
or
0066
Sorry, the FAQ says it all.
Just swapped out my battery and discovered the need for a radio code... after the fact.
CDR-220
Type 4462
S/N X5026275
Assistance would be greatly appreciated.
Thanks much,
Paul
CDR-220
Type 4462
S/N X5026275
Thanks much,
Paul
Try 8732
or
8730
Hello Loren,
I lost my stereo code for my CDR 220 and cannot use it anymore...
Here are the specs:
type: CDR 220
Model No: BE 6625
Serial No: 15001676
EC:102
Accession No of Product: 0110580
Date of Manufacture 27/01
Could you please help me???
Best Regards
Hello Loren,
Here are the specs:
type: CDR 220
Model No: BE 6625
Serial No: 15001676
EC:102
Best Regards
Try 8291
or
8289
Hi, Loren congratulations :clapping: for your site, its perfect... I bought a 996 2001 and need the code for the radio is a:
CDR -220
SERIAL X5052800
BECKER 1
THANKS FOR THE HELP
CDR -220
SERIAL X5052800
BECKER 1
THANKS FOR THE HELP
Try 2677
or
2675
Thanks Loren for your fast reply, I tried the code 2677 and 2675 and dont function, I have more info if case you needed
becker 1
type 4462
cdp2081
ser. Y 5052800 (i put an x before and is a y)
Thank you
Edited by Loren
Removed ALL CAPS - please do not post in ALL CAPS
Another lost soul here who just purchased a Porsche/Becker radio/cd unit without the code, to replace the existing cassette radio. The info on the unit is CDR 220, Model Number (BE 4462), Serial Number (15086889) Can anyone here help me out as I understand that there is a way to get it.
Thank you in advance for your help as I am going to try to install it for my wife before she gets back from her trip to NY as a surprise for her birthday.
OK, after a lot of inputing numbers I decided to try calling a local Dealer and found to my surprise that they were very helpful. It took 24 hours for Porsche to get back to them BUT Porsche asked for the VIN of the Boxster as well and then quickly gave out the code after I provided it, for no charge. Security is my guess.
So my advice is to try this route first, it may save a lot of frustration.
One other item is that eveyone wants you to buy the little knife shaped radio removal tools to take the radio out. I found that if you have a couple of Victronix pocket knives with the screwdriver head on the file, they work great in removing the radio. Just insert into the slots at an angle out and then just straighten them out, out it pops. It helps to have another hand to do this though. :D Thanks to all...
