3 hours ago, Daniel Rodriguez said:
Good afternoon
New to Porsche. Replaced battery and now looking for radio code. Hopefully thus is the only thing to do when replacing battery..
Have: 1999, 911 C4 with Becker 1, Type 4362, W5010192, 45/98 (??)
Thank you,
Daniel Rodriguez
Try 3289
  • Thanks 1
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
On 9/20/2022 at 8:25 AM, Loren said:
Sorry, I wasn't sure it would work on such an old radio.
Hey Loren, do you think if I unhook my battery it might reset my radio to where my code would work?
I know I am using the right code I talk to the previous owner. Is there may be a few codes I could try? Thank you so much for the help.
Disconnecting the battery should not make a difference - sorry.
Did you use the procedure in the Lost Radio Code FAQ
If you did not, please do so and repost.
If you did, then it is likely that your radio may have been repaired by a third party - if that is the case I cannot help you - sorry.
Loren,
It’s been 10 years since I posted on here. Hoping you can help me with a lost radio code.
CR-220
M- 4632
Ser - W9002514
it could also be W5002514 as my pixels are going bad on that bottom row.
thanks so much!
50 minutes ago, ruf965 said:
Loren,
CR-220
M- 4632
Ser - W9002514
thanks so much!
Try 9832
I have a CDR-210 and am trying to get the serial number to display.  It says to press the tone button and then 8 and 0 to bring up the Becker display.  I don's see any 0.  I have 1-8 * TP  What am I doing wrong?  Thanks!
Hi Loren,
I'm in need of a radio code
2002 Porsche Boxster
type: cr 220
model: be 4362
serial no: y5025012
Edited by whitechr
3 hours ago, whitechr said:
Hi Loren,
type: cr 220
model: be 4362
serial no: y5025012
Try 5251
New (to me) 2002 Porsche Boxster S, CDR-220.  New alternator, lost the radio code - hoping someone out there can help...
Type 4362
SER 15002827
24/99
Thank you!
Jeremy
Type 4362
SER 15002827
24/99
Thank you!
Jeremy
Try 6478
Hello Loren, I just got my first Porsche, a 2000 Boxster S. Can you please help me out with a code?
CR-220
Type 4362
Ser X5019201
47/98
Thank you!
Edited by gskrap
CR-220
Type 4362
Ser X5019201
47/98
Thank you!
Try 1092
