  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
6 hours ago, Martin Zhang said:
I just bought a 1998 Boxster, and I would appreciate your help in obtaining the radio code.
CR-210
R 3297
Serial: V5007550
Thank you!
Try 1496
same here. Took delivery with battery disconnected. No code.
Becker CR220
Model BE4362
Serial 15032048
Any help with getting code would be appreciated.
Edited by Gerhard Schiller
typo
27 minutes ago, Gerhard Schiller said:
Becker CR220
Model BE4362
Serial 15032048
Try 0104
1 hour ago, Loren said:
Try 3019
I love you. That worked. Is there anywhere I can donate to you or the website for this?
Hi I am new and hoping you can help with a code.
I have a CR-210 with a serial number of V5005206.
Any help would greatly be apreciated.
Thank you!
Thank you!
Try 4786
Thank you!!!  I will try tonight!!!
That worked great!  Thank you very much for the help!!!
Edited by drubes
Halo,
can You please help me with the radio code for 2001 Carrera4
CDR-220
Y5052042
Type 4462
Send please per E-Mail adamjachec@gmail.com
Thank You very much
Adam
6 hours ago, adamjachec said:
Halo,
CDR-220
Y5052042
Type 4462
Thank You very much
Adam
Try 9141
4 hours ago, arethusa71 said:
Hello. I need a code for my Becker CDR-220 serial number X5035057
Hope you can help!
Thank you.
Try 9195
  • Thanks 1
had to disconnect the battery and lost my radio code.  here is my vin #WP0CA2986XU624676
my 1999 Boxster
Thank you for the assistance
Blake
my 1999 Boxster
Blake
Your VIN does not have any radio info. We need your radio serial number.
From the Lost Radio Code FAQ ...
"How to get your radio serial number?
CR-220/CDR-220:
Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
Or, if the radio is out of the car the then the serial number is on the label.
CR-210/CDR-210:
Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
Or, if the radio is out of the car the then the serial number is on the label."
