Brake Fluid Change - How much to drain ...
I'm just following the DIY for changing my brake fluid - it advises removing as much old fluid as possible from the resevoir. I assume this is to avoid wastage in mixing old and new fluid ? I'm using an empty pressure bleeder to just remove the old fluid via a normal bleed nipple at the moment - I'm down to the 'min' mark but have noticed a black large diameter plastic pipe coming from the right of the resevior. Should I go below this for less wastage or will this introduce air into the clutch via this pipe ?
Many Thanks,
Richard.
Many Thanks,
Richard.
It doesn't matter. Just fill up your pressure bleeder with fuild and go for it. Don't forget the clutch bleed.
....Don't forget the clutch bleed.
I looked at the DIY.... Is the bleeder valve like the ones on the caliper? i.e. can you connect tubing to it?
Also, I have a G86.20 6-speed...same bleeder as shown in the DIY?
I'm planning on pulling the car out of storage and doing this first thing. Thanks for any help.
--Brian
