- View Classified Ads
- DIY Tutorials
- VIN Decoder
- Special Offers
- Paint Codes
- Registry
- Videos System
- View Reviews
- Send attachments with PMs
- Option Codes Lookup
All Activity
- Yesterday
Tam TKF joined the community
Daniel Yeung joined the community
hua zhu joined the community
- Last week
DustinD changed their profile photo
Hervé Poilpre joined the community
Werner Schaefer joined the community
ninetynine996 changed their profile photo
Hey everyone, I'm nearly done wrapping up a cooling system refresh on my MY99 C2. I opted for the genuine Porsche 996.2 coolant tank. I'm having an issue getting a snug fit for the coolant tank sensor. I went with a unit from Hamburg technic. It seems possible to only slot the sensor in one direction. Once it's seated it's not possible to spin it in order to lock it into place. Am I running into an issue with the aftermarket sensor spec? Short clip of my issue below. Thanks in advance!
PCCM+ install
OscarAH1W replied to kestrel88's topic in 997-1 Series (Carrera, Carrera 4, Carrera 2S, Carrera 4S)
I put it in my 2004 Turbo Cab and it works great. plug and play though playing content through your iphone is not as loud as the normal stereo... you don't have to purchase the NAV card; you can use apple carplay... works a treat. Hope that helps. -
Bobby Chau joined the community
Paul Andronic joined the community
CharlieN17A joined the community
Darrin Wagoner joined the community
Matthew Streiff joined the community
Charles Fiery changed their profile photo
Non starting project
mark kehe replied to mark kehe's topic in 9PA, 9PA1 (Cayenne, Cayenne S, Cayenne Turbo, Cayenne Turbo S)
Bit of an update... Have cleared all the transfer case and transmission codes through the replacement of the TC motor and fixing a bad connection at the drive selection switch. I still have the Gateway 1336 "CAN comfort OFF" fault along with Stability Management 1826: Steering Angle Sensor, "Terminal 30 Power Supply" fault and an Advanced Weight system 0470 "CAN single wire operation" fault. While these are persistent (and annoying) I don't see why they would be contributing to my no crank/start state. I went back and rechecked the trigger signal at the starter relay and I am getting a pulse but it isn't enough to trigger the relay (I have replaced and swapped the relay with a known working one.) Continuity of the wiring between the relay and the KESSY tests good. The ground of the KESSY module also tests good. Battery is new and good. I have run the KESSY test in PIWIS and the test sequence confirms the trigger signal but stops with "no response received." I have no faults with the KESSY. I know there are known issues with the KESSY components associated with the comfort access going bad but this seems like something different. Any thoughts.... - Earlier
I have a 2006 C2S and was wondering if anyone has installed a PCCM+ (non Bose). How does it sound compared to the original stereo? I don't have Nav, is it possible to get navigation with the new one or do you have to buy all the other hardware to get it? Does PCCM+ receive the HD channels? TIA Bill F.
Key FOB Programming procedure for?
alex222 replied to 996C4SC's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
For the steps #1: I don't know of what are the doubts about these steps as for the sq. #1 there is same button on the keyfob for all 996/986 to lock/unlock. Which cannot be pressed TOGETHER as it is just the same button. Brrr.... Steps #2: I never tried these steps but for 996/986 programming the keyfobs and immobilizer are separate procedures. Even if hypothetically these steps would add the 2nd keyfob to the car with shortened pins #1 and 4; the key needs to be programmed to the immobilizer. -
Josh Schnitzer changed their profile photo
gizmoe107 started following Lost Radio Code
Need help with a radio code for: 2002 Boxster CDR-220 Becker 1 type 4462 ser 15009152 Thank you!!!
Chih-Wen Chino Yang changed their profile photo
Weird stalling problem
JFP in PA replied to geoff's topic in 997-1 Series (Carrera, Carrera 4, Carrera 2S, Carrera 4S)
If the oil cap is hard to remove, you have a high vacuum level in the sump, which is bad for a variety of reasons, including lean stalling. The correct way to access the AOS is to fully warm up the engine by driving the car for 10-15 min, then replace the oil cap with the one in the picture above with a hose that connects to the digital manometer. If the vacuum level exceeds 6-7 inches of water vacuum, the AOS is leaking air into the intake system, causing the lean stall conditions. The normal level of vacuum is typically 4-5 inches of water, which is a really weak vacuum level, so it doesn't take much of a leak to cause problems, which is why we always checked every car that passed thru the shop with the manometer. -
geoff replied to geoff's topic in 997-1 Series (Carrera, Carrera 4, Carrera 2S, Carrera 4S)
I asked my service advisor last night for specific measurements, but all I got back from him was "Oil cap hard to remove", which in all fairness is his level of mechanical expertise and understanding (he came from Porsche sales and doesn't know much about how the cars actually function in terms of problems, and the techs know this, but he does go out of his way not to sell unneeded work). I don't doubt the AOS is starting to fail after 14 years and around 150K miles (no visible symptoms yet), but more worried that replacing the AOS won't solve the cold start stalling problem (only stalls after initial cold start in the morning with the headlights on, but never after that). I'm going to the dealership to talk to the techs and get the details firsthand, and will report back what they say. And it's not like I don't spend enough at the dealer that they need to make more money off of me. I went deer hunting on a canyon road at 60 MPH, and instead of filing a comprehensive claim with my insurance for my '08 Cayenne, I'm having the dealer fix everything, including subletting all the body work. -
JFP in PA started following Weird stalling problem
The AOS can either be pin pointed or eliminated by having the car's sump vacuum level checked with a digital manometer (most quality shops have them as the AOS is a perpetual issue; surprise the dealer didn't do this). -
Loren replied to geoff's topic in 997-1 Series (Carrera, Carrera 4, Carrera 2S, Carrera 4S)
See if any of the fault codes have changed. If not, then I would still go the path based on the FRAU readings. -
Thanks Loren, as always! None of these are sounding like they are caused by the AOS going bad, are they? I'm going to visit the dealer to see what's going on tomorrow. From the way my wife has described the symptoms, it seems like it would be a fuel or electrical issue causing the car to sputter and/or die. The CEL didn't start until after the first visit where the tech cleaned the throttle body. Before that, it was idling smoothly, just stalling. I'll see if I can get more details. Anything else this could likely be? -
P2189 Lambda control adaptation FRAU (lower load range) (FRAU > 0.7) - below limit value Possible fault causes - Incorrect main filling signal from hot-film mass air flow meter - Fuel pressure too high - Injection valve faulty (dripping) - Tank vent faulty (does not close completely) P2189 Lambda control adaptation FRAU (lower load range) (FRAU > 1.3) - above limit value Possible fault causes - Intake system leaking (secondary air) - Incorrect main filling signal from hot-film mass air flow meter - Leak in exhaust system - Fuel pressure too low - Fuel injector faulty (stuck) - Fuel pump delivery too low P2187 Lambda control adaptation FRAU (lower load range) (FRAU > 0.7) - below limit value Possible fault causes - Incorrect main filling signal from hot-film mass air flow meter - Fuel pressure too high - Injection valve faulty (dripping) - Tank vent faulty (does not close completely) P2187 Lambda control adaptation FRAU (lower load range) (FRAU > 1.3) - below limit value Possible fault causes - Intake system leaking (secondary air) - Incorrect main filling signal from hot-film mass air flow meter - Leak in exhaust system - Fuel pressure too low - Fuel injector faulty (stuck) - Fuel pump delivery too low -
geoff started following Weird stalling problem
Original owner 2005 997 Carrera Tip, 191K miles, my wife's daily driver. Engine replaced by Porsche in 2011 around 60K miles when IMS bearing let loose. Lately in the morning on cold start, the car stalls at the end of the driveway first thing in the morning with the headlights on. Then runs OK, or sometimes stalls one more time in the next block. Doesn't stall when the headlights are on, but stumbles once or twice in the first few minutes of driving in the morning, then all is fine. Took to the dealer (never had any complaints), and the tech cleaned the throttle body. Check engine light came on by the time I got it home and the car continued to stall in the mornings. I'm in So Cal, so cold start is in the 50s outside temperature. Codes are P2189 and P2187, which indicates the engine's air-fuel mixture is too lean on bank 2 and bank 1 while idling. Tech then said found broken line for brake booster and replaced. Check engine light still on. Car still stalls. I then replaced the 9 year old Optima with a new AGM battery, but that didn't solve the problem. Back at the dealer this morning. Service advisor is now telling me the techs think it's a bad AOS, even though the car isn't smoking. Story is coming from 3 techs, including shop foreman. Their diagnosis was based on oil cap is hard to remove, and "oil filler neck is sucking in". I asked for what pressure measurement they got for crankcase vacuum, but didn't get a straight answer. Before I spend $4K to replace the AOS, which doesn't seem to me that it's the cause of the problem because there's no smoke on startup, what else should I have them look at?
Robert Habibi changed their profile photo
Thanks for the input. Dealer put in new plugs and swapped coils with no change. Saying the misfire count is very intermittent and that all coils are firing normally. Here is what they said "tested for misfires and monitored misfire count and found a small 1-3 count and multiple cylinders. Swapped coils and plugs for cyl 1,3,4 and found small misfire counts still present in same cylinders. Drove vehicle and found the misfire counts are very sporadic but will not re set the fault". Is it possible that the harness supplying power to coils could be the culprit? Just a random thought. Appreciate your help.
JFP in PA started following Cold Start Mis Fire
jcphx1 started following Cold Start Mis Fire
Joe Questel changed their profile photo
P1276 Signal Delay Time for Oxygen Sensor Ageing, Bank 2 – Above/Below Limit Possible causes: – Oxygen sensor ahead of TWC – Leak ahead of TWC or in the area of the oxygen sensor after TWC – Wiring (oxygen sensors exchanged)
stateofidleness started following P1276 on 2000 Boxster
Hi all - getting my Boxster back on the road. Has been garaged on trickle charger for about 8 months. I've driven it the past couple of days with no issues, but today, I got a solid CEL (P1276 when I used my code reader). Below are the "live" values I was able to capture from the code reader. From what I read this points to 02 sensor. I have cat bypass pipes and aftermarket muffler on my boxster, but I have the stock headers (and don't remember ever messing with 02 sensors during the swap). To be honest, I dont know if this means I have 2 02 sensors or 4 on the stock headers. There's no 02 bungs or sensors on the cat pipes or muffler. Can yall tell me what best plan of attack is here? 2000MY non-S with roughly 95k miles and no other issues present. Param Value Bank1 Sens1 02S Outp 0.100V Bank1 Sens1 STFT 6.2% Bank1 Sens2 02S Outp 0.110V Bank1 Sens2 STFT 99.0% Bank2 Sens1 02S Outp 0.600V Bank2 Sens1 STFT 2.3% Bank2 Sens2 02S Outp 0.710V Bank2 Sens2 STFT 99.0% Engine RPM 828 Fuel System 1 Closed loop Fuel System 2 Closed loop Load Value: 3.50% LTFT Bank1 -13.20% LTFT Bank1 -11.70% STFT Bank1 5.40% STFT Bank2 6.20%
Max Viger changed their profile photo
Hello all! I replaced my driver-side front window recently and replaced the window frame guide. After getting everything back together and driving the car I heard a faint whistling at the top of the window which wasn’t present prior to the replacement. Upon inspection I noticed around a 2mm gap at the top right corner of the window frame guide where the window frame guide should sit against the aluminum trim. I tried loosening the 3 compensating socket bolts on the sides of the door and my adjustment helped a little, but I am still left with a gap. My next plan is to heat-up the area with a heat gun and gently pull the area where the gap is… would this be a bad idea? Anyone have any noninvasive suggestions for addressing this?
