Leaderboard
Popular Content
Showing content with the highest reputation on 02/28/2019 in all areas
  1. Thanks for the PN! Doesn't look very expensive, my local dealership has it for $26 and the o-ring is less than $2. I think the thermostat is on the back of the 3.2 V6 but for the 3.6 V6 the thermostat is on the side of the engine (driver side). I know this because I replaced it during my cooling system refresh at 90k miles. However, there does seem to be a housing for something back there, I'm just not sure what it is..
    1 point
  2. I've had the same problem in my 2008 v6. After removing the 2 bolts I saw it had a rubber gasket. Waiting for the dealership to call me when it comes in. (Was the cheapest there) It's technically for the thermostat. It's called a flange socket and sealing ring. Here's the part #'s 95510623100 Flange Socket 95510643100 Sealing Ring Sent from my iPhone using Tapatalk
    1 point
  3. So, again in an effort to help others that might look for this in the future: 996 GT3, Airbag Light and Durametric fault " Code 30, ignition circuit - side airbag, passenger". Side airbag = door airbag: There was nothing wrong with it, the connector was good, and I also electrically swapped a spare airbag that I had, but the fault remained. Knowing the issue was coming from that circuit, and since I had disconnected the door and the controller when I stripped the car, I looked at both of those, looking for a bent pin, or? I expected the door connector to be the bad player since it's a bit less straightforward to connect and disconnect than the controller. While trying to identify the relevant pins on the big connector at the door jam to wring out the wires, I noticed that, with the connector off, the two pins/wires for the door airbag were shorted together (no doubt a shunt to prevent accidental airbag deployment when the connector is not connected). I also noticed that, in the connector, right next to the two pins, there was a small rectangular slot that matched a small plastic piece on the mating connector. At first I thought that it was an alignment device, but there was more to it than that, because there was a small piece of metal in the slot. While ohming the two airbag pins, I shoved a pick in the slot and suddenly, the two shorted pins/wires were no longer shorted, meaning that THE PLASTIC PIECE HAS TO BE ALL THE WAY INTO THE RECTANGULAR SLOT so that the circuit is in an acceptable state for the airbag controller. So again, even if the connector appears to be connected, you need more than just the pins to be in contact, you need the plastic tab to be all the way in to the slot. These pins and slot are part of a sub-connector within the main door connector and the sub-connector is somewhat free to move a bit. I made sure that it was all the way in and now my airbag light is gone. I'm sitting in the car with the laptop, having gone back in with the Durametric to clear the code, and decided to tell my story. Hopefully it can help someone. Case closed :)
    1 point
  4. IMHO it would be really useful if some of you guys could reply with which code Loren suggests actually works. It might help make more accurate predictions. Just my 2 cents worth.
    1 point
