  1. Brake discs (Boxster) Front - 298 mm Rear - 292 mm Brake discs (Boxster S) Front - 318 mm Rear - 299 mm
  2. Sorry, should be working now.
  3. According to the schematic... C1 pin 6 is switched power for the amp. A pin 5 is the antenna amplifier connector. The is no power antenna line.
  4. As I recall it can take 2-5 minutes to initialize a PCM unit after it has had power removed. I think it has to go through a self-calibration and then try to locate itself.
  5. http://www.renntech.org/forums/index.php?s...ost&p=12801
  6. I think you might need more cylinders to get that sound ;) I think the PSE and Tubi have more of a "raspy" sound than the others.
  7. You need to test with the fender liner off so you can see where the leak is. The two option left are the motor and the tubing. Of course if you have headlight washers that adds three more options...
  8. Basically just look at my 3rd Radiator Install Instructions here. It is the same process. We are doing this on Chuck Jones car on Saturday so I'll see if Chuck will take some fresh pics too.
  9. Have you checked the fuse?
  10. Yes and no. Some parts are the same some are different. You will need to be more specific (including model of both).
  11. :welcome: Please give our search feature a try - many things have already been covered here. http://www.renntech.org/forums/index.php?s...ost&p=41789
  12. I think your only choices are "CGT" or "911".
  13. Navteq makes the disks for all Porsche NAV systems. In some countries you must order from Porsche and in others they send you to Navteq.
  14. Remove and install should easily take less than 1 hour. With a good cleaning it might take a bit longer.
  15. I'm pretty sure that programming the Sport Chrono option requires that the dealer get an IPAS code directly from Porsche (just like for a new key). Porsche will verify that the option was paid for (either on the original order or on dealer installed paperwork). Likely they did this to keep the dealers honest. I guess you could always go with a third party re-map - if all you want is throttle/DME mapping.
  16. Sunset Imports (Porsche Parts at Dealer Cost).
  17. Have a look at Replacing Rubber Bellows Under 996 Rear Spoiler in the DIY section.
  18. Try 6401 or 6403
  19. Porsche POSES say 3.8 hours for a clutch replacement.
  20. You should read TSB 8/02 1360 Dual Mass Flywheel Check Procedure -- dated Dec 13, 2002. Porsche AG warns dealers about replacing flywheels that are not defective. Have you considered an independent shop? My guess is that an indy will do it for less than $1000.
  21. Sorry to disappoint, but having worked for the worlds largest "mouse company" I don't think there is much hope unless you can find someone that wants to buy the other 999,950 units.
  22. Loren
    GT3 ECU Pins
    Does anyone know what's the pin #/wire for the tach signal at the DME for a MY04 GT3? Just as I quoted above - it is easiest to take it off the OBD II connector. If you must take off the DME it is pin D17 (same violet/green wire.
  23. I suggest to go to tire rack and read the section on Uniform Tire Quality Grade Standards (UTQG) (http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=48). The UTQG specifies the wear grade, traction grade and temperature grade of a specific tire. Then look a the UTQG ratings for the Porsche approved tires and the UTQG rating for the tire you would like to purchase. My feeling is that if the the UTQG meets or exceeds the Porsche N rated tires then you are likely okay to use those tires.
  24. Boxster and Carrera doors have different part numbers - so there is likely a difference. Porsche would surely use the same part if they could...
