  1. Did you say the seat does move? IIf not, then I would start with fuses.
  2. Try 9709
  3. See if any of the fault codes have changed. If not, then I would still go the path based on the FRAU readings.
  4. P2189 Lambda control adaptation FRAU (lower load range) (FRAU > 0.7) - below limit value Possible fault causes - Incorrect main filling signal from hot-film mass air flow meter - Fuel pressure too high - Injection valve faulty (dripping) - Tank vent faulty (does not close completely) P2189 Lambda control adaptation FRAU (lower load range) (FRAU > 1.3) - above limit value Possible fault causes - Intake system leaking (secondary air) - Incorrect main filling signal from hot-film mass air flow meter - Leak in exhaust system - Fuel pressure too low - Fuel injector faulty (stuck) - Fuel pump delivery too low P2187 Lambda control adaptation FRAU (lower load range) (FRAU > 0.7) - below limit value Possible fault causes - Incorrect main filling signal from hot-film mass air flow meter - Fuel pressure too high - Injection valve faulty (dripping) - Tank vent faulty (does not close completely) P2187 Lambda control adaptation FRAU (lower load range) (FRAU > 1.3) - below limit value Possible fault causes - Intake system leaking (secondary air) - Incorrect main filling signal from hot-film mass air flow meter - Leak in exhaust system - Fuel pressure too low - Fuel injector faulty (stuck) - Fuel pump delivery too low
  5. P1276 Signal Delay Time for Oxygen Sensor Ageing, Bank 2 – Above/Below Limit Possible causes: – Oxygen sensor ahead of TWC – Leak ahead of TWC or in the area of the oxygen sensor after TWC – Wiring (oxygen sensors exchanged)
  6. Could be the fram or the window is warped. Does the frame seal properly around the door?
  7. The larger (lighter) near object is a turbocharger - if there is oil coming out of that then you likely need a new one. I am not sure if anyone can rebuild them these days or not.
  8. P1531 Actuator triggered, no active position. - Open circuit in triggering wire. - Open circuit in B+ supply. - Actuator faulty. P1689 is not a valid code for MY1999 C2. Perhaps check again?
  9. No the code is by Becker serial number - and Becker made both.
  10. From the Lost Radio Code FAQ... "CDR-23 (or later): These radios do not have a security code - that is, not that the user enters. These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  11. Try 7571
  12. Try 1098
  13. Try 3268
  14. You need to go to a Dealer/OPC to get the update. Usually there is a cost involved.
  15. Look at both the plug and socket on the car sometimes the connectors can be pushed out of the socket when inserting the headlight. There could also be damage to either due to someone pushing too hard and breaking either the socket or plug.
  16. I would start by checking the grounding points on the starter and the chassis. Also look for damaged starter cables.
  17. Have checked the cable to the back of the unit? If any dash/console work has been doe this may have come loose.
  18. Try 7213
  19. PM me your exact VIN and I will look it up in the Porsche database.
  20. Try 2984
  21. Try 4184
  22. Try 5843
  23. Try 5320
