  1. Try 2765
  2. Try 0525
  3. Yes, pretty much a direct part replacement. It is best to disconnect the battery and let the engine program re-learn the idle and power curves after the new installation.
  4. Okay, I see now. You can rent or buy a spring compressor or... Attach the top 3 studs and bolts first - then carefully use a bottle jack (or floor jack) to push the bottom of the shock up to the mounting point.
  5. Use the weight of the car to compress the spring -- carefully. I have done this dozens of times.
  6. Try 6524
  7. Lower the car just a tad so that the upper mount will go through. You need a little pre-load.
  8. Try 8765
  9. That serial number looks too short. Please check the serial number useing the method in the Lost Radio Code FAQ
  10. Please read the Lost Radio Code FAQ "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  11. I would bundle and cover the electrical connectors so they can not touch chassis ground.
  12. Try 6432
  13. 1. Switch off ignition and remove ignition key. 2. Use a plastic spatula to carefully unclip the covering frame, starting from the bottom left and right. 3. Unscrew the four fastening screws. 4. Carefully pull out the PCM unit. 5. Press lock on antenna connectors 1, 2, 3, 4 and pull off antenna line. 6. Release central connector for PCM 5 , fold up release (arrow) and remove connector from PCM. 7. If the PCM unit has to be replaced and a telephone control unit is installed:
  14. It would likely need to be re-programmed for LHD options (not in alarm section).
  15. :welcome: The alarm module, DME, and transceiver are all programmed together - so theoretically that could work. If the car is originally from Germany then the cats are likely a different spec - you will need to check local laws to see if they are approved for use in your country or not.
  16. Try 8704
  17. Try 0708
  18. Your duplicate post was deleted per board rules. Back to the topic please...
  19. Try 9050
  20. Starting in MY2007 wiring diagrams are only available in PIWIS. There is no easy way (that I know of) to print them from PIWIS. Seems like the simplest solution would be to get a valet key.
  21. Try 7029
  22. Try 5852
  23. Try 4712
  24. I am looking it up in Porsche's database - and it says "not a valid VIN". Send them a message and ask for a (good) photo of the VIN.
