  1. Try 8659
  2. Try 9092
  3. Try 5634
  4. 955 555 557 01 A03 retaining frame Black -- US MSRP $107.76 Looks like a lot of transfer work...
  5. From the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  6. Please PM me your VIN so I choose the correct color part number. Thanks.
  7. Try 3682
  8. The key must be in the ignition and power on to use the PIWIS. It can still tell you what any faults are (CAN-BUS) as well as module states.
  9. Try 2941
  10. If you could post a photo that would be great!
  11. Try 5351
  12. The car shows signs of a battery failure and perhaps replacement without resetting the codes. Try clearing all the codes -- drive the car and see what comes back.
  13. Sorry, I am not seeing a clip on theat parts diagram.
  14. Can you tell me exactly where that panel is on the car? I thought it was a rear door/seat panel.
  15. I didn't find anything in the service manual. Here is an exploded diagram that may help. My guess is that you will need to remove the rear hatch door liner to bolt it in place.
  16. 955 555 278 00 Clip US MSRP $0.74 each
  17. Try 4815
  18. There should be fault code(s) for PSM failure. If iCarsoft does not report that then you will need DUrametric or PIWIS to get the faults reported.
  19. Try 4569
  20. For sure with a Porsche PIWIS tester - perhaps with Durametric, and other scanners may be hit or miss.
  21. From the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  22. Did you check the crankshaft position sensor? If it does see the engine running then it cut off the fuel supply.
  23. Try 9390
  24. This is your third request - please consider a donation to this site for it's continued operation. Try 1062
