  1. In my experience when you fix a problem that affects the "Ready" state it takes some time of driving to accumulate enough good test results to change the state. I have seen this with both O2 sensors and SAI issues.
  2. That part does not show in the parts list so I think you are looking at a salvage yard or replacing the whole under deck lid cover. Sorry.
  3. Hmm... i think the GT2 only has the one opening for the air filter cool air intake on the right side. Perhaps an aftermarket spoiler?
  4. Ok - Model and year of the car please? Did you install a GT2 spoiler/rear lid?
  5. Try this for your photo... PicResize - Crop, Resize, Edit images online for free! PICRESIZE.COM The original FREE picture resize and crop tool since 2005! Resize, crop, compress, add effects to your images, photos, and screenshots for free!
  6. Did you use the procedure in the Lost Radio Code FAQ to get the correct serial number (in the display)? If not, please do so and re-submit the correct serial number.
  7. Looks like it's 996 512 334 01 - Intake manifold Air Filter -- about $44 US MSRP
  8. I think you mean Jake Raby of LN Engineering. The DVD is on sale right now for $299. Jake Raby's Porsche M96/M97 Engine Rebuild DVD LNENGINEERING.COM Rennvision’s Focus on: M9X Engine Assembly by Jake Raby goes step by step on how to correctly rebuild a Porsche M96 or M97 engine in this 5 disc DVD set.
  9. You will be able to more diagnostic testing with the Porsche tool. Autel will identify faults but won't necessarily let you run further component test.
  10. From the 981 parts diagram it does not appear to have the same adjustment capability.
  11. Lo siento, no vi que fuera un Porsche Traffic Pro. Tratar 13425
  12. It depends on how much of the travel he used the first time. Sorry, but inspection is the only clue.
  13. I have an Autel MS906 BT (as well as a PIWIS 3). The Autel worked fine on my 2017 Macan GTS. It is nice that it is Bluetooth so you just plug in a transmitter plug and hold the tablet (no wires). Still it was about $1300.00 and requires are yearly subscription to continue to get updates (first year is included). As I recall the updates subscription is about half the cost - so I paid $695. They do occasionally have a discount on subscriptions.
  14. P0131 Oxygen sensor upstream NOTE: The fault "Over limit value" is detected if the oxygen sensor voltage is > 1.5 V for an uninterrupted period of more than 5 s. Diagnostic conditions - DME control module power supply 10.5 V … 16 V - Oxygen sensor heater switched on for > 70 s - Oxygen sensing active - Exhaust temperature 600 °C (1,112 °F)... 750 °C (1,382 °F) - min. 3 s overrun - No secondary air injection or diagnosis of secondary air system active - No tank ventilation or diagnosis of tank ventilation system active - No other oxygen-sensor faults stored Possible fault causes - Fault in oxygen sensor heater A If this exists, is to be taken care of first - Loose contact or corrosion in the connector - Short circuit to B+/ground/between wires or open circuit in the wiring - Heater injection - Oxygen sensor faulty - DME control module faulty
