  1. Try 6835
  2. Try 4325
  3. Try this for your photo... PicResize - Crop, Resize, Edit images online for free! PICRESIZE.COM The original FREE picture resize and crop tool since 2005! Resize, crop, compress, add effects to your images, photos, and screenshots for free!
  4. Did you use the procedure in the Lost Radio Code FAQ to get the correct serial number (in the display)? If not, please do so and re-submit the correct serial number.
  5. Try 4702
  6. Looks like it's 996 512 334 01 - Intake manifold Air Filter -- about $44 US MSRP
  7. I think you mean Jake Raby of LN Engineering. The DVD is on sale right now for $299. Jake Raby's Porsche M96/M97 Engine Rebuild DVD LNENGINEERING.COM Rennvision’s Focus on: M9X Engine Assembly by Jake Raby goes step by step on how to correctly rebuild a Porsche M96 or M97 engine in this 5 disc DVD set.
  8. Item 2 in the last diagram.
  9. You will be able to more diagnostic testing with the Porsche tool. Autel will identify faults but won't necessarily let you run further component test.
  10. From the 981 parts diagram it does not appear to have the same adjustment capability.
  11. Try 2454
  12. Lo siento, no vi que fuera un Porsche Traffic Pro. Tratar 13425
  13. Tratar 9427
  14. It depends on how much of the travel he used the first time. Sorry, but inspection is the only clue.
  15. Try 6453
  16. I have an Autel MS906 BT (as well as a PIWIS 3). The Autel worked fine on my 2017 Macan GTS. It is nice that it is Bluetooth so you just plug in a transmitter plug and hold the tablet (no wires). Still it was about $1300.00 and requires are yearly subscription to continue to get updates (first year is included). As I recall the updates subscription is about half the cost - so I paid $695. They do occasionally have a discount on subscriptions.
  17. P0131 Oxygen sensor upstream NOTE: The fault "Over limit value" is detected if the oxygen sensor voltage is > 1.5 V for an uninterrupted period of more than 5 s. Diagnostic conditions - DME control module power supply 10.5 V … 16 V - Oxygen sensor heater switched on for > 70 s - Oxygen sensing active - Exhaust temperature 600 °C (1,112 °F)... 750 °C (1,382 °F) - min. 3 s overrun - No secondary air injection or diagnosis of secondary air system active - No tank ventilation or diagnosis of tank ventilation system active - No other oxygen-sensor faults stored Possible fault causes - Fault in oxygen sensor heater A If this exists, is to be taken care of first - Loose contact or corrosion in the connector - Short circuit to B+/ground/between wires or open circuit in the wiring - Heater injection - Oxygen sensor faulty - DME control module faulty
  18. Try 0723
  19. Try 9054
  20. You need to re-train the windows. Hold the down button until it is all the way down and then continue holding for 10 seconds. Do the same for up on the window. Now the windows should work properly and one-touch should be reset.
  21. I don't know for sure I have never measured that. If that P1517 is your fault code then there is only one solution given in the service manual - "perform adaption".
  22. P1517 Throttle Adjusting Unit: Abortion of Test due to Negative Influence on Ambient Condition - Above Limit Note: This fault is only recorded if the adaptation was not performed correctly after the throttle adjusting unit or DME control module was replaced. Possible cause of fault - No adaptation performed The following conditions must be satisfied to ensure that the adaptation is performed: - Do not actuate the accelerator pedal (for instance, make sure that there is not a carpet pressing on the pedal) - Vehicle is stationary - Battery voltage between 10 V and 16 V - Engine temperature between 5 °C and 100 °C - Intake air temperature > 10°C 1. Switch the ignition on without starting the engine 2. Using the 9588 Porsche System Tester ll perform a "throttle adaptation" under the "System adaptation" section (the notes above must be observed)
  23. Sorry, your serial number layout confused me. Try 8537
