  1. You must mean the right front fender (left to right as you sit in the car). The gas filler is on the right. You could have a stuck fuel tank vent valve or a crimped fuel hose.
  2. If the car will not lock/arm with the key fob buttons - start with a new battery in the key fob.
  3. You will also need to remove the left (as you sit in the car) wheel well liner to get full access to the radiator and mounting. If you pinch the hoses with clamps you will lose the minimal amount of coolant. follow the bleeding instructions in my 3rd radiator DIY in the 996 DIY Mods section. The "rubbery/plastic things for guiding the air to the radiator" is just called air duct and you will need to order it by side of the car too.
  4. Terminal 30 is always unswitched power (+12 volts) Terminal 31 is always ground
  5. :welcome: Nice rides!
  6. Yeah, slbates is right now that I see a pic I remember they are not the push pin type. Must be old age creeping up on me... ;)
  7. this is great news! are the plastic rivets bolt on? or do they require a special tool to install the lip? also OT, Loren have you ever been stumped by a question on this board =X As I recall the rivets are just push on - similar (if not the same as the wheel well liners). :lol: :lol: :lol: I get stumped all the time... then I look things up, ask more knowledgeable people, and ask the poster more questions to help clarify the issue. With the help of lots of folks on this site someone usually steps up and helps. I think we are right more often here than your local dealer - and I think that is because of all the experienced Porsche fanatics here. At least that is my feeling...
  8. There is a TSB that explains it all in detail. As a Contributing Member you can read all the TSBs here online.
  9. Just a few points of clarification... When you program a key you must have ALL the keys present. There are only 4 key slots available in the immobilizer - so max keys is 4. When you replace a bad key you need the good keys so you know which key code is the bad one to program over. If don't have all the keys present you run the risk of programming over a good key and leaving the bad key program in the immobilizer (wasting a spot or disabling another key). As Kim said the key blank (blade, metal part) must be cut to fit the car (ignition and door). Never buy a "new" or "never used" key without the 24 digit key code tag. Without the tag the key is worthless and can be programmed to a car.
  10. LOL... more press releases = more notice (at least in the company execs minds). Oops... my 30 plus years in marketing kicked in there :P
  11. 996 612 070 30 Electric wiring harness (for fixed rear wing aerokit) I do not have a diagram of what is different on this harness.
  12. We have added and/or updated TSBs in the following categories (7 TSBs total): 996 - 1 (found missing TSB from 2002) Cayenne (gen 1) - 3 Cayenne (gen 2) - 3
  13. P0420 Catalytic Converter Conversion Too Low (Cylinders 1 - 3) Potential causes: Bad Three Way Converter (cat) You did not read that here. That is not true.
  14. Do a search here for "drains". You will find locations and cleaning instructions.
  15. For oil changes? I'm afraid I disagree - perhaps the largest ripoff in the industry.
  16. The C4 and C4S parts are already in the parts lists. If you order a MY2009 C2 right now you will likely see it it in September. I suspect the C4 and C4S are not far behind.
  17. I have found that TSB and added it here. The TSB talks about reduced factory fill and a new dipstick.
  18. Item 5 996.505.986.00 spoiler lip -- MSRP $76.34 I am sure Sunset Imports (Porsche Parts at Dealer Cost) has a much better price. You may also need the attaching plastic rivets 999.507.427.40 (11 required) -- MSRP $0.21 each
  19. You already posted this question once - please re-read the board the Guidelines/Rules about double posting. "Please post your messages in one forum only. Crossposting, double posting, triple posting, etc. are all a waste of time and valuable resources. If you post the same message in multiple times or in multiple forums, we will delete the ones we feel are inappropriate."
  20. You can reset it with the Durametric Software, a PST2, or PIWIS tester.
  21. The only "approved oil" is: 999 917 547 00 Esso ATF LT 71141 – 20 liter container You might ask a knowledgeable oil supply for an equivalent.
  22. Try 7199 or 7197 Neither worked :( Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  23. Does "P" show in the cluster signifying you are in Park?
