  1. Try 4120
  2. Try 8520
  3. Back to the original posters question please.
  4. Try 4298
  5. Try 1579 hi,loren,sorry it did not work.thank you Did you use the procedure in the Lost Radio Code FAQ to get your serial number? If not, then please read that and follow the procedure and re-post the correct serial number here.
  6. Try 0109 Tried it, but it did not work. Entered the code and then the asterisks just came back. Is there a button that needs to be pressed after entering the code (the manual does not say so)? Thanks for helping! No, just entering the code should start the radio working on a CDR-220. Did you use the procedure in the Lost Radio Code FAQ to get your serial number? If not, then please read that and follow the procedure and re-post the correct serial number here. Hi Loren. Yes, we did use the procedure from the FAQ to get the serial number. Thanks for the help. See below: Loren, Any additional thoughts? Thanks! That (0109) is the code for that serial number. Perhaps your unit has been repaired or otherwise altered. Sorry.
  7. Please read the Lost Radio Code FAQ "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  8. Try 1579
  9. Try 0715
  10. Try switching the bulb from one side to the other - if the fault follows the bulb you know where the problem is.
  11. Most common problem like you have described is dirt and debris in the button mechanism. Sometimes an air blowout will remedy without dis-assembly.
  12. Those two systems have no connections to each other - which is why I say that it can not make any difference.
  13. Try 8792
  14. We are talking about a 2003 or newer 996 (with MOST fiber optics) right? 1. Yes, you will likely need a PST2 or PIWIS to code the radio and add the radio in the MOST setup. 2. That will depend on the other (MOST) options on your car. I have posted the diagrams here on the site (please search). 3. Ask others on that one. 4. CDR-23 Radio to amp connection requires the MOST fiber optic cable. So if you want to use the CDR-23 you will need either the BOSE amp or the Harmon amp. The output of the amp to the speakers is always a wired connection. 5. Again this will depend on your cars options - the BOSE amp supports 6 speaker and a sub-woofer.
  15. Try 0109 Tried it, but it did not work. Entered the code and then the asterisks just came back. Is there a button that needs to be pressed after entering the code (the manual does not say so)? Thanks for helping! No, just entering the code should start the radio working on a CDR-220. Did you use the procedure in the Lost Radio Code FAQ to get your serial number? If not, then please read that and follow the procedure and re-post the correct serial number here.
  16. Try 4565
  17. Try 0109
  18. You have posted 3 times with two different serial numbers and still no model name (on the front of the radio). No radio model - no code -- just that simple.
  19. +1 I highly recommend this method - it can save you hours and hand injuries.
  20. If your car does not have PCM (or never had it) then just ignore the PCM faults. I have see false errors with a PST2, and PIWIS on 996 series cars that do not even have PCM. Perhaps someone else has a source for connectors...
  21. So are you saying everything is working but the code do not clear? If that is the case then Durametric may not be able to clear them and you will likely need a PIWIS or PIWIS 2 tester to clear them. As I recall PIWIS is also capable of running a CAN test.
  22. Looks like that document is not available in PIWIS. If you look at all the other 997-2 logos they are all 45 mm up from the bottom edge of the rear lid. Then centered on the lid left to right.
  23. Try 0782
  24. Item 17 - Fastening part? If so, 996-631-077-00 -- US MSRP $23.92 each
