  1. Tiptronic or Tiptronic S transmission? The 5-speed Tiptronic S available as an option for the new 911 Turbo (997) is a further development of the transmission used in the 911 Turbo (996).
  2. Does your car the build code for sport suspension? If you are not sure PM me your VIN and I will check it.
  3. Updated parts list (your's is 15 years old). 997.1 rear strut.pdf
  4. Do you have any fault codes? Fault codes are critical for diagnosing these sorts of problems.
  5. Not before checking to see if the purge line is open and the purge valve is working.
  6. My guess would be fuel level or leaking back into the vent line.
  7. The first thing the car (US/Canada cars) does when you turn the key is look for a fuel or vapor leak. Leave the gas cap off or if the o-ring is bad will cause a similar issue.
  8. Front: 235/40ZR x 18 Rear: 295/30ZR x 18 These worked fine on my car (MY99 996 Coupe). My front wheels were 8" not the stock 7.5". I do not think you can go any wider on the front and very little on the rear.
