RFM
Everything posted by RFM
  1. The use of a diagnostic device is always the best route to go, the problem may have multiple causes such as defective fuses, broken or damaged wiring, corroded plugs into the connectors, incorrect or broken microswitches to a faulty window/door ecu, which is a unit with the motor.
  2. The rear trunk emergency cable is located behind, and on the rear side, of the left inner wheel well.
  3. It could be connected to the engine hood lock, for the indication on the display " Engine Hood Open" This is my best guess honestly. Give it a try.
  4. You may never let the engine running while refueling, fuel system operates under a specific pressure by environement regulations, controled by the DME. This fact alone is already a reason for a MIL.
  5. I would first repair the coil problem and the fuse, probably an internal short in the coil itself, the starter could be related to the work you have done on the alternator, loading ok? connections ok?
  6. The control of the fans is realized by a PWM signal via the fan control box, however the operation is more complex, DME 7.8-CAN (high speed and comfort)-GATEWAY-AC-ENGINE/COOLANT/ENGINE ROOM/OUTSIDE temp. sensors and the board network control box are involved.
  7. I think you better restart the operation, there is probably an internal leak, loose or wrongly connected tubing/pump, electrical connection or even bad pump.
  8. Remember that, just like the brakes, the shock absorbers also warming up by the friction on the in and out movements. The fact that the wheel sensors are replaced remind me of weak shock absorbers, the sensors go thereto defect.
  9. Have you filled the circuit with a vacuum device? Without a tool it is very difficult to get all air pockets out of the circuit. New water pump faillures are rare but not impossible, the rotor sometimes does sit loose on the shaft, but i'm guessing on air pockets.
  10. Hopefully you have disconnected the battery, fumble on yellow connectors can end badly with power on. This is just a warning to prevent your health.
  11. Check whether the alternator freewheel pulley is not jammed, this causes excessive vibration in the poly V belt which can break off mounting bolts.
  12. The plastic tubes have to be replaced if damaged, they are vacuum tubes which, inter alia, controlled the resonance flap in the plenum and other vacuum operated parts. Leave it as it is not an option.
  13. Do a test drive with the OEM exhaust in order to know the difference in value, 200 cell cats can occasionally show strange problems when they are no longer optimally.
  14. Without the use of a vacuum filling system it shall be a time-consuming and hazardous task, any trapped air bubbles are indeed very difficult to remove without vacuum tool.
  15. When only leaking pistons are replaced calibration is not necessary, but when the entire system has not completely or partialy reached the points of reference (microswitches) a calibration is needed.
  16. The connecting rod between the lock cylinder and the door lock mechanism is not connected properly or defective. You will have to start over, the connecting rod looks like a mini oar, the flat end of the rod falls into a groove of the door lock. Since the remote controle turns itself off after about six days, this is a problem whitch must be solved as soon as possible.
  17. Is true of all sensors, spark plugs and coils, OEM parts turn out the cheapest in money and time. Happy for you that it is resolved.
  18. Multiple components are shared under the VAG group vehicles, so it would be more than likely.
  19. The engine temp. sensor to the control box seems to falter in the vicinity of 40F in this case, the values should be compared with a new one under the same circumstances.
  20. Concerning your last video "Surging idle", the parking brake must be engaged for a proper measurement when the wheels are off the ground, otherwise the transmission and the wheels are a little dragged by the engine, causing a slight difference in RPM at idle due to no torque.
  21. Bank 1 is on the driver's side on 996 LHD cars, also the waterpump side.
  22. Are the waterhoses, on the back of the engine (in the middle of the V) well connected in the right order? There are 3 or 4 of them and are not connected in the logical way.
  23. It is the vehicle which is programmed to the key fob, not the key fob to the vehicle.
  24. Before going to be done useless work or made costs, check with a diagnostic/programming device the status of the control boxes, probably they sould be returned in "Vehicle Handover" modus. Sometimes they jump back into factory mode.
