JFP in PA
  1. According to the parts system, you should have a free wheeling pulley on the alternator. That said, if the car does not have one, and you are not the original owner, it may have been changed out at some time.
  2. If he would like to PM his VIN to me, I could tell him what is supposed to be in the car.
  3. Porsche parts list the alternator both ways in 1999, so it did exist with the free wheeling pulley that year..
  4. I wonder if those sensors are not applicable to my car since the values never change? The other fuel trim readings seem normal. If you take a look at post #5, I took a photo of the diagnostic screens that my reader has when it's hooked up with the engine off. It shows the above two readings for the sensors that stayed fixed as well as the other fuel trim readings that seemed to be changing appropriately with the diving conditions. Are the readings for STFTB1S2 and STFTB2S2 supposed to change? The spark plugs used on the car (according to the receipt) are: (7410) FR6LDC (I think he meant to write LDU not LDC) Those should be correct according to the manual, however I don't know the torque they used since it was a shop that did it before I owned the car. They were done 3 years and 7,000 miles ago. I thought that I read somewhere that cars with a performance tune (I have the Ultimate Motorwerks tune) eat through spark plugs much quicker and it may help to go with one step colder. Is there truth to that? Couple of thoughts: Yes, most "tuned" turbo cars benefit from running at least one step colder plugs. Secondly, have you tried measuring the same fuel trims but using a Porsche specific scan tool (Durametric, PST II, PIWIS)?
  5. Center of photo:
  6. That voltage should be more than enough. One item to consider is your brake light switch; there have been multiple reports of failing brake light switches causing ABS and/or PSM faults which promptly went away when the switch was replaced.
  7. I've seen failed mounts, but I was wondering if there is an easy way to see, or test them on this actual car. I didn't look at them carefully. Maybe I can just grab the engine and shake it to see if it moves? If I am correct, they should be very easy to change on this car, right? I have a lift in my garage, so that should make it even easier. I'm not near the car now, so I can't look now. It's very possible that the mounts are bad because I always felt that the car idled a little rougher than I thought it should. I was just under the impression that it was normal because everyone says that they are a little rougher than the Boxsters and that's what I compared it to. I had a 2001 Boxster S You will need to support the engine while swapping them out, and may find that access from above may be restricted by some stuff that is removable, but they are not overly hard to change out: There are also multiple aftermarket vendors of "improved" mounts that use replacement materials like urethane to improve their strength, but also tend to impart higher vibration in the process. Because the turbo engine is a race derived unit, it shakes a bit more than the more pedestrian M96/97 street engines. If the mounts are really bad, you can usually see the engine move when someone revs it.
  8. And these are the actual engine mounts:
  9. Usually the rubber in the mount is either torn or has sections totally missing. This happens to be a transmission mount insert, but it will give you the basic idea:
  10. There is no problem with the way it runs, or the sound. Everything I'm complaining about has to do with the feel. It just feels like a rough or unrefined engine for a little while after a cold start. The RPM's start that high (~1,200) but after warming a little, they settle down to 800 rpm. There are no drivability issues. All of the turbo cars have a bit of a lumpy idle when compared to the normally aspirated cars, but many times idle vagaries can be traced to failing motor mounts. If it was a failing motor mount, wouldn't it vibrate all the time? I guess it does feel the same as a bad mount, but it only does it for a short time and only on a cold start. The idle doesn't stay there. That is only when it is initially started cold. It settles in at 800 rpm, which I believe is perfectly normal. I agree, it seems to be a very difficult troubleshoot, I'm usually very good at troubleshooting, but this has me stumped! My best bet is probably to go to a mechanic that knows these cars very well so they can check it out. For all I know, it may even be a normal characteristic of these engines. Bad engine or transmission mounts usually show up only under certain circumstances, which is why they often get overlooked. When the engine is "loping" at idle, it is really trying to move around quite a bit, so a weak mount would make if feel even worse than it really is. I also would expect the car to normally run at higher RPM's than the regular idle speeds on a cold start.
  11. All of the turbo cars have a bit of a lumpy idle when compared to the normally aspirated cars, but many times idle vagaries can be traced to failing motor mounts.
  12. I would have to agree with jpflip, your first step should be to try recalibration of the steering system before spending any money.
  13. As you will most likely be altering the vehicle's tire aspect ratio (http://www.yokohamatire.com/tires_101/reading_your_tire/aspect_ratio/) when you make this type of change, things such as ride height, quality, and steering response will also change in response to the stiffer sidewalls on lower profile tires.
  14. The codes you might see are not specific to the belts, only that the airbag system is faulty.
  15. Any pending codes would have appeared with the active codes. I would have to agree with RFM's assessment, you may have to test voltages when the fault appears.
  16. I seriously doubt your brake sensors would cause this. My first inclination would be to scan the car with a Porsche specific scan tool (Durametric, PST II, PIWIS), looking at both active and pending codes. Low voltage excursions are know to cause these types of problems, yours may be intermittent, which would be why the MIL would clear itself.
  17. The company selling them, under their "EuorpeanParts" name, is the same company pushing the roller bearing IMS replacement, which has already drawn some heat elsewhere.
  18. It will have to, there are no undersized bearings for these engines.
  19. Sometime back, Sunset Porsche was selling several brand new 986 manual sets, with updates, for around $400.
  20. Try disconnecting the alternator power lead and see if that drops it.
  21. Some where in the car, something (probably an aftermarket item) is wired in as "always hot", and you need to locate it. 150mA is still three times the drain the car should have.
  22. And people wonder why I dislike these aftermarket kits. Because of the energy required to run a HID headlight, the HID bulbs do not run on low-voltage DC current, so they require a power pack (ballast) with either an external or internal ignitor, which controls the current given to the bulb. Considering automobiles use a 12-volt electrical system for their lamps and the HID lighting requires over 20,000 volts to ignite the bulbs and then 85 volts to keep them running, the ballast is a necessary part of the system. Apart from turning it on it also regulates the voltage, and is an integral part of the HID system. The power-up of the bulbs happens in three phases. First comes the ignition, when a high voltage pulse is used to produce a spark which ionizes the Xenon gas, creating a tunnel of current between the Tungsten electrodes. After this comes the initial phase, when the temperature in the bulb capsule rises rapidly, the metallic salts vaporize and the resistance between the electrodes fails. Most likely what has happened is that the ballast or high voltage igniter in your kit has failed and has sent a high voltage spike backwards into your lighting harness, damaging something in the harness network. As we can only hypothesize what has happened, you are going to need to get a wiring diagram for the car and start electrical testing diagnostics to find out where the problem lies. You could have fried the alternator diode bridge, the voltage regulator, burned part of the harness itself, or even the dash light switch. Good luck.
  23. Try this: http://www.wikihow.com/Find-a-Parasitic-Battery-Drain
  24. Not really, we have seen all sorts of things create drain. But this process will help you isolate it quickly.
