JFP in PA
  1. This can be a bit more thorny than just a bumper; a lot of Euro spec cars need to have both their crash speed ratings (bumpers, etc.) switched over, as well as their emissions systems to meet US standards, after which the car has to be certified to meet US specs. There are also differences in the lighting systems (head lights, DRL, etc.) that need to be addressed as well. You need to do some serious research on this, there are firms that do it, but the cost often exceeds the values of doing it and many just sell their cars and buy a US spec version when they get here.
  2. I'd really like to know how they repacked your wheel bearings, they are sealed units: I am beginning to think that you need to have another set of eyes, ones with a bit more Porsche experience, look at this car. Your "grinding" noise could be wheel bearings, or CV joints; but someone that tells you they repacked bearings that can't be repacked needs to be replaced..............
  3. I always go back to the last thing touched when codes sudden show up. As mentioned, P0455 is the "large leak" EVAP system code, which obviously includes the gas tank; one neat trick in this department: Jury rig a rubber stopper or something similar to replace the gas cap (we actually took a new cap, drilled and tapped a hole in it that we then screwed in a threaded fitting to connect to a vacuum gauge) and check for a steady low vacuum on the tank with the car idling. If it is intermittent, or non existent, or worse yet there is pressure, there is a leak somewhere that has to be tracked down. You can still have a loose connection on the O2 sensors as a vacuum leak is more prone to cause the car to throw overly lean O2 codes rather than a poor electrical connection code.
  4. How well I remember.................
  5. I think any change in the car's handling characteristics resulting from spacers is more perception than reality. Most people use them simply to get "the look".
  6. Along with the gas cap, you could have a bad EVAP canister (cracked), a disconnected hose (there are several), a bad valve at the EVAP canister, etc. You could also have a fuel filler neck related issue, or simply an air leak into the fuel tank where the fuel pump enters. This is the kind of problem that the smoke machine to find vacuum leaks was developed for; quite often, visual inspection in not sufficient to find these leaks.
  7. The Purge valve should not trigger the EVAP related code he is seeing, but is worth a look in any case..
  8. P0455 is the code for a large vacuum leak in the EVAP system, often a loose, missing or defective gas cap. P0134 and 0154 are for a poor electronic connection (read loose plug) on both upstream O2 sensors. Find and fix the vacuum leak, clear the codes and see if the O2 sensor codes return; if they do, check all the harness connections before even thinking about replacement.
  9. You are going to want to run a very high ZDDP oil designed for new engine break in periods, like Joe Gibbs BR product. I would not run this for more than 400-500 miles.
  10. As long as the hose is not dry, brittle or hard; just cut a bit off and use it.
  11. There are a lot of lines with barbed fittings used in the automotive markets which do not require clamps; the line is single use (it cannot be pulled off and reused, it has to be cut down past where it last fit on). In fact, you should not use clamps on these barbed fittings as the clamp will cause the line to be cut by the barbs. Here is an example on a Jag, the little metal cup at the end of the hose is permanently on the barbed fitting and is just there to dress the end of the hose; no clamps used:
  12. You have not provided year and model data, but I think the line in your picture is a simple push on and a barbed connection by the fuel pressure regulator.
  13. StaBil has come up with a couple solutions, the well known red product will do an excellent job of preventing fuel from deteriorating during storage, including those that carry up to 10% ethanol in most environments. They recently added the term "Storage" to the label of this product. This is the product we have used very successfully for many years with customer's cars in storage. If you are in a particularly moist area (seaside, etc.), have higher ethanol contents, or for use in marine applications, they now have a blue-green product (labeled "Marine") specifically to address the higher water and corrosion risk while in storage. While this product was designed for more troublesome environments, it can be used for storage in less aggressive conditions as well. They now also have a specific product for diesel applications as well. For most people, particularly if they store their cars in a controlled environment (read heated garage) will do just fine with their familiar red product.
  14. As long as it meets the basic configuration requirements that Durametric lists on their site, you are golden..............
  15. A dealer would be in the $150-200 range, and Indy about $120.
  16. It can be run on a Mac, but you need one of those special shells and a full version Windows 7 to do it, which makes it expensive. By a cheap Windows laptop and just grit your teeth................
  17. Have him re check it at 15 min. and 30 min.; if you see drop off, you have a bleed down somewhere in the system, often at the fuel tank flange area, which houses the valve that is supposed to prevent bleed down.
  18. Jeff, what do you recommend then, as a regiment, for the DFI Porsche engines? Thanks. You need to run a good quality fuel, and dose the car with Techron before every oil change. It is also a good idea to get the system "power flushed" with a pressurized cleaning system on a regular basis, and probably at least once a year. DFI engines are a major improvement in both technology and performance, but as usual there is no free lunch............
  19. You need to proceed with caution; you already know that the car has some prior issues, you need a thorough PPI done by someone that knows their stuff before making an offer.
  20. Yes, but be cautious about which bulbs you use, a lot of the aftermarket "brighter bulbs" are higher wattage and can discolor or even melt headlight components.
  21. It does not take much to aggravate these injector systems, just a little build up of varnish or crud is enough to make the car respond. The newer DFI cars are even worse as the injector is in the combustion chamber. Interestingly, cleaning the piston domes tends to actually take performance away. A layer of carbon ash on the piston dome acts as an insulator, helping to hold heat in the combustion chamber longer, yielding better output. This is the basis of technology used by firms like Diamond or Swain who ceramic coat piston domes and cylinder head combustion chambers on race engines.
  22. How about some experience instead? For decades, Porsche has recommended running a dose of Techron in their cars for this exact purpose. We have used in in the shop since the day we opened our doors. Our standard "pre-hibernation" service recommendation's include running a full tank of Techron dosed fuel through the engine just before bringing the car in for its last service of the season in preparation for putting the car away for the winter, which includes an oil and filter change, pre winter battery and coolant system checks, and a full inspection of the car's systems. Afterwards, air up the tires, a full tank of fuel dosed with StaBil, a full cleaning of the car, hook it up to a battery maintainer, and put the dust cover over it until spring. Never had one start the next season with fuel system related issues in more than thirty years. I cannot make that statement about cars that were not dosed with Techron before storage. We sometimes get a poor running car in the shop with no codes or other apparent issues. Sometimes we see them with codes indicating a possible of one or more leaking injectors; as a precursor to spending a lot of time and the customer's cash, we have them invest $15-20 in a bottle of Techron and run the car for a couple days. More often than not, the problem disappears. We have had the opportunity to bore scope cars before and after using Techron, you would be amazed at the difference in the combustion chambers and the tops of the pistons, which is why you should always change your oil after using it. Techron is not a "miracle in a bottle", but it does live up to its claims.
  23. That's much better. Ask your mechanic how he adjusted the level of the fluid after refilling the trans (there is a specific proceedure to do this), otherwise the trans may not have the correct level of fluid in it.
