JFP in PA
  1. If it is the pulley, the pulley is one Hell of a lot cheaper than a replacement alternator.......................
  2. I'd also check the alternator to see if it has the de-clutching style pulley, which can also make quite a bit of a racket when it craps out and can leave the alternator unable to put out enough voltage.
  3. I'd wager that the codes are for RKAT values would indicate an overly lean O2 codes for banks 1 & 2 at idle.
  4. They should not be this tight, go back and recheck the rod and crank sizes as well as clean out the threaded areas.
  5. You need to carefully run a thread chaser through all threaded items, followed by a blast for clean compressed air to be sure the threaded areas are totally clean before any assembly is possible. If you have not done this, go back and do it, otherwise you will get all sorts of erroneous torque readings.
  6. Did you run a thread chaser through the rod bolt holes first to be sure they are clean?
  7. Yes, but it begs a question: Are you torquing them dry or lubed? Logray also has a point about checking the big ends for roundness after bench torquing them, as well as checking the crank.
  8. First, I see you used new rod bolts which is good as you should never reuse the rod bolts on these engines, never. Correct specs are 20 nM (15 ft Lb.) + 110 degrees of torque angle.
  9. K&N has long been a proponent of using much larger filtration media pore sizes for supposed improved air flow, but coated with oil to try and get back some of the filtration properties. Only problems are that on the dyno, you gain next to nothing, but are allowing a lot of dirt and other debris by and into the engine. When the filter is cleaned by washing, and then recoated with oil, it is difficult to determine the correct amount of oil to use, and often ends up having the excess oil carried on the airstream into the MAF where it can coat the film and cause no end of issues. Not a recipe for either performance or longevity............ Stay with the stock filter.
  10. As much as others may protest, these filters are a waste of money. No real gain in power or torque, poorer filtration, a decided chance of oiling your MAF; all at a price substantially higher than the stock unit, which is a fine unit to begin with.
  11. Only problem is that this type of test will not find issues like the fuel filter problem described earlier, or a pressure regulator that is on its way out intermittently under load conditions. Granted, if the car cannot pass the static test, there is a problem; but some cars pass the manual test just fine, but then crap out under load, which requires testing it dynamically to spot it...............
  12. Keeping the temporary test rig outside the car is purely for safety and to reduce any potential for having to get the smell of gas out of a customer's car. At 120Bar, a leak that would be a small drip on the 50-60 PSIG system turns into a torrent that can literally slice through flesh in a heartbeat; really not anything to be messing with, even if you ignore the fire potential. We are looking at obtaining an suitable electronic pressure transducer to temporarily mount on the engine that would eliminate the need for a line and gauge.
  13. Depends upon what we are looking at; sometimes the fuel pressure and delivery is so low at an idle, trying to run it at higher revs becomes a moot point. Other times the idle pressure looks good, but bringing up the RPM’s (free revs) shows a sudden fall off, indicative of a fuel pump or regulator issue. That said, other times we have rigged up cars to take on a road test with the fuel pressure gauge taped to a window for observation purposes while pushing the car to look for a sudden drop off in pressure. We once had an early Boxster come back with a poor performance complaint shortly after a major service; turns out the new fuel filter was bad (internal obstruction caused by loose components) that only showed up with the jury-rigged pressure test setup and a “run it hard” road test. At idle or free revs, it looked fine. We have seen similar things when the fuel pressure regulator gets intermittently problematic. Sometimes you just have resort to “man invents tool” to figure out what to try next……….. I really can’t wait to have to do this kind of testing on one of the newer DFI cars running big time fuel pressure; the test rig line will have to be braided stainless to deal with the pressures (120 bar or about 1,740 PSIG) involved instead of the 35-60 PSIG of the early cars………..
  14. These engines are timed using a special tool the holds the cams in the correct positions using the slots on the end while the engine is locked at TDC. Do a search, been covered before..................
  15. Typically, the code thrown when the pump cannot supply enough fuel is for an overly lean condition (O2 sensors) or a general misfire (P0300-0306). I would suggest scanning the DME and see if any "pending" codes of that nature show (sometimes the pump is just bad enough to only lean out at very high RPM's, but then the fuel trims drop back in range when you take your foot out of the engine, leaving only the pending codes rather than active ones because the condition did not persist long enough). It would also be very easy to attach a pressure test gauge to the test port on the fuel rail and check both the pressure and delivery rates, only takes about 15 min. shop time.
  16. Suggest looking at the fuel system; M96/97's that have fuel delivery volume or pump pressure issues act this way, but only under load. You could just simply be running out of fuel at higher revs...............
  17. Just be aware that disabling the airbags and driving the car will most likely result in a MIL light and code, which requires either the PIWIS or Durametric software to clear.................. We like to let the car sit with the battery disconnected for 5 min. before going near the airbags.
  18. There is very little difference in sound output between the base 2000 muffler and the S unit; the only real difference is the tips. You would be better off looking for a used PSE, which has a better note without the drone of aftermarket stuff. As for using 911 headers on a Boxster, unless you have a lot of time on your hands, and a good MIG/TIG welder, I would suggest against it. The engine in a 911 is facing the other way around (the engine is behind the gearbox in a 911 rather than in front of it as it is in a Boxster), so one Hell of alot of fabrication would be required to get this working.
  19. I don't know where you got your price quote, but you can buy the Stant pressure tester (STA 12270) for $72.38 on Amazon, or $69.78 at ToolTopia. As for Porsche adaptors, there are two; 12016 will test the vehicle and sells for about $40; 12017 will test the cooling system cap, and sells for about $10. I have two of the Stant testers, and an entire case full of adaptors to fit just about anything, and I didn't pay anywhere near $500 for everything.......................
  20. That is not necessarily correct, the air bags can deploy when the light is on; the light is just an indication of a fault and does not necessarily disable the entire system. The service manual has a procedure to follow whenever working on, or around, the air bags. It starts with disconnecting the battery for a period, and suggests wearing a grounding strap to prevent building up a static charge and setting the system off. You may want to do a search to get all the info on how to safely do this. Be careful, at close range and airbag can and will seriously injure or even kill.
  21. The LN adaptor actually keeps the filter slightly higher up than the stock set up, so ground clearance is not an issue. When installing, be sure to lube the inside and outside o-rings with oil, and torque to spec. When putting on a new spin on filter, be sure to lightly oil the gasket and only tighten the filter 1/2 turn past hand tight (we regularly get question about why the adaptor is coming off with the filter, and it inevitably is because no lube on the gasket and then King Kong tighten it.........). Installed properly, the filter comes off without the adaptor.
  22. You can try cleaning it, but I would not hold out a lot of hope.
  23. It does not drain the system, only refills.
  24. That's weird, as the product is made in Canada...................
  25. Do a search, this has been discussed about a zillion times. Connect a maintainer to the lighter socket, connect a battery to the fuse panel, use the emergency cable under the front..................
